February 09, 2026, 04:58:46 PM *
Author Topic: Left turn signal  (Read 774 times)
~ Ron ~
It's the right thing to do
Ahwatukee, Arizona
« on: November 29, 2014, 08:47:05 AM »
The left turn signal blinks faster than the right.  I've changed the light, I've changed the turn signal relay, I've disconnected the rear half of the trike and it still blinks fast.............it's a 2000 Valkyrie/DFT trike crazy2
~ Ron Pierce ~
~Ahwatukee, Arizona~
~VRCC 20050~
~TOI  27850 ~
~2000 Valkyrie / DFT ~
« Reply #1 on: November 29, 2014, 09:01:49 AM »
Check the wires in the headlight, kinda sounds like a ground issue and maybe the wires weren't connected completely in the headlight and have come loose.
Just a thought.
« Reply #2 on: November 29, 2014, 09:15:18 AM »
Are both front and back lights blinking?
Tailgate Tommy
Fort Collins, Colorado
« Reply #3 on: November 29, 2014, 09:37:16 AM »
Check that the front bulb is in correctly. If it's 180 degrees off it will blink fast.
~ Ron ~
Ahwatukee, Arizona
« Reply #4 on: November 29, 2014, 10:08:25 AM »
Tkylli................the points on the bulb are off set so it can only go in one way........................ cooldude
Big head..............yes both lights are blinking.......... Smiley.
Hook # 3287.............. I will check the wires in the head light , thanks Smiley
~ Ron Pierce ~
~VRCC 20050~
~TOI  27850 ~
~ Ron ~
Ahwatukee, Arizona
« Reply #5 on: November 29, 2014, 12:15:35 PM »
Well.............I checked the wires on the headlight and there all tight............Cobra doesn't make this light bar anymore or I could just change out the left side........................ it works fine with my trailer on soooooooooooooo I think your right .......a ground issue..............thanks
~ Ron Pierce ~
~VRCC 20050~
~TOI  27850 ~
Valkpilot
What does the data say?
Corinth, Texas
« Reply #6 on: November 29, 2014, 12:30:42 PM »
Even with the offsets, they can be inserted 180° off.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Tailgate Tommy
« Reply #7 on: November 29, 2014, 03:30:45 PM »
They absolutely can be inserted 180 off -I've done it! crazy2
