February 09, 2026, 04:58:43 PM *
Author Topic: Chrome Brake Caliper  (Read 854 times)
Algonquin Highlands, Ontario Canada
« on: November 30, 2014, 05:43:28 AM »
Good morning,
I recently purchased a complete rear caliper assembly off a 2001 Interstate which I am considering having chromed to put on my 2000 standard. If someone could answer a couple of questions it would be greatly appreciated;
1. Is there anything I should know before taking it to the chrome shop; what to remove, what to leave in place, any preparation required?
2. After researching part #'s and seeing a difference, are the parts (pistons & seals) interchangeable     between the Interstate caliper and the Standard caliper?
« Reply #1 on: November 30, 2014, 05:57:01 AM »
Nope  Wink ...
I've never tried to put an Interstate caliper on a Tourer/STD, but there's no possibility
of putting an Interstate piston/seal into a Tourer/STD caliper...
« Reply #2 on: November 30, 2014, 12:28:28 PM »
Nope  Wink ...
Thanks, I guess I should have done some research first, I will see if it fits the next time I have the rearend apart. If the whole assembly fits I will rebuild with new seals and pistons.
« Reply #3 on: November 30, 2014, 02:16:58 PM »
I M H O any caliper you want chromed I would TRY VERY hard to NOT have the caliper piston bores chromed. Chroming would make the bores smaller doncha know! RIDE SAFE.
« Reply #4 on: November 30, 2014, 05:00:30 PM »
Good thought, I will check with the chrome shop as to how they avoid doing that.
quexpress
Montreal, Québec, Canada
« Reply #5 on: December 01, 2014, 05:59:01 PM »
A "GOOD" chrome shop is "supposed" to know that. If they don't, don't walk away ... run!
Good luck!  cooldude
I still have a full deck.
I just shuffle slower ...
