February 09, 2026, 11:00:29 PM *
Author Topic: galfer brake lines  (Read 1397 times)
da prez
Wilmot Wi
« on: December 06, 2014, 02:44:00 PM »
Every time I go to E-bay or Amazon to try to get front , rear brake lines and clutch lines , they come up as not fitting. I called Galfer a while ago and the kid (ding-bat) said he could not guarantee the fit for my Valk.
 Does anyone have the correct part numbers for a 98 Standard/Tourer.
  Thanks in advance.
                              da prez
 (I am reserecting another 98 Tourer, will be for sale in the spring)
BobB
« Reply #1 on: December 06, 2014, 05:59:11 PM »
I had planed to install new brake lines in my '98 Tourer this winter.  I didn't realize there may be a problem.  I'll start searching and keep everyone advised.
flatsixrider
2000 Standard
Greenville, SC
« Reply #2 on: December 06, 2014, 06:37:02 PM »
I've been running lines from Spiegler for years.  Quality lines and they fit.
http://www.spieglerusa.com
Sometimes the appropriate response to reality is to go insane.
big poppa pump
San Antonio, TX
« Reply #3 on: December 06, 2014, 07:31:27 PM »
This is the Galfer clutch line I got for my Valk. Ended up going with Goodridge for rear and front brakes (dual lines).
http://www.ebay.com/itm/331174673815?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #4 on: December 06, 2014, 08:19:24 PM »
I'm only going by memory here, and may be totally wrong.
I thought Carolina Bikes and Trikes sold hard lines for the Valkyrie (or it might have been for my ACE Tourer).
gregor
« Reply #5 on: December 07, 2014, 01:03:19 PM »
  Thanks in advance.
                              da prez
Hi,
Here you have the original numbers:
- Galfer Rear Brake Line > FK003D49R
- Galfer Front Brake Line > FK003D49F
- Galfer Clutch Line        > FK003D49CL
Good luck in your search  cooldude
Gregor
VRCC #25500
da prez
Wilmot Wi
« Reply #6 on: December 09, 2014, 08:01:13 AM »
   Thanks to all. This board has all the answers. I try to help out when I can.
                            da prez
Farther
Quimper Peninsula, WA
« Reply #7 on: December 10, 2014, 08:50:36 AM »
Not Galfers but from a forum sponser:  http://www.xf6-custom.com/partpages/valbrakelines.html
~Farther
BobB
« Reply #8 on: February 26, 2015, 05:16:04 PM »
I just found a source for Galfer brake lines at MadcoRider.com.  The front set is listed at $98 on the site but after a price check, they came out to be $131.  They can make allowances for longer upper lines to accommodate risers or other handlebars.  The lines are ordered from Galfer as orders come in to MADCO.   I have delt with this little company before, they are top notch.  I am using their Cam-Lock (throttle lock) and their Drink-Caddy.  Bill, a VRCC member, rides a '98 Standard and is a joy to talk to.
I have no association with this company, other than a client.
Jack B
Two Rivers Wis
« Reply #9 on: February 26, 2015, 06:24:46 PM »
I had Galfer lines on my Tourer, sorry can't help with part number's I bought them at the Chicago Cycle show from Galfer many years ago.
If you want my stock one's you can have them. I can give them to you at Fox and Hound next month. Unless you want them sooner.
Let’s RIDE
« Reply #10 on: February 26, 2015, 06:57:35 PM »
I just measured the lengths I wanted for the front brakes, then rode over to J&P Cycles in Daytona and bought what I needed. Bought a single line to go to the lower tree where I mounted a splitter. Then two separate lines to go to the front calipers. Got the clutch & rear brake line from Barnett as I recall.
CoachDoc
San Diego, CA
« Reply #11 on: February 27, 2015, 04:08:33 AM »
Also try Slingshot. He makes great quality S.S. lines in a variety of  colors. Great quality and excellent
service.
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
mello dude
Dayton Ohio
« Reply #12 on: February 27, 2015, 03:55:13 PM »
If you take the time to measure and figure out what fittings you want - Coremoto is a very good source. Lines made to order.
http://www.coremoto.com/Core_Moto_Performance_Brake_Lines_s/306.htm
btw - Speigler is a great source too. I live 10 minute away from them, and used them for my VFR lines.
« Last Edit: February 27, 2015, 03:58:17 PM by mello dude » Logged
