February 09, 2026, 04:59:34 PM *
Author Topic: shock rebuild  (Read 1933 times)
baird4444
« on: December 12, 2014, 10:15:14 AM »
Dang these shocks are pricey!
old schoolers used to rebuild shocks, can these be rebuillt?
    if so, where would I get the parts, pretty much just seals...
                  - Mike
    - ya gotta be SOBER!
     -Cody Baird
« Reply #1 on: December 12, 2014, 12:43:26 PM »
Honda OEM rear shocks are not re-buildable, there are no parts available.
There was an Aussie that claimed to have found new springs that would fit, but don't know how that worked out.
Most people replace with Progressive shocks.
Farther
Quimper Peninsula, WA
« Reply #2 on: December 12, 2014, 01:10:54 PM »
Or Works, or OEM.
~Farther
« Reply #3 on: December 12, 2014, 03:23:39 PM »
Or Works, or OEM.
    Or low mileage originals IF they can be found.  cooldude RIDE SAFE.
8Track
Adelaide, South Australia
« Reply #4 on: December 13, 2014, 04:39:28 PM »
Here's my thread on rebuilding my original rear shocks. It worked out just fine!
http://www.valkyrieforum.com/bbs/index.php/topic,45903.msg435963.html#msg435963
« Reply #5 on: December 14, 2014, 05:21:30 AM »
Hey Mark;
How are your springs holding up?  Are you still happy with the switch?
The ebay link states the springs are not available.
I'm guessing the chrome cover fits as designed and you can't see the new spring?
« Reply #6 on: December 14, 2014, 05:31:21 AM »
Mark;
Another question, I've never really inspected the shocks closely, always just taken them off, put them to the side, then reinstalled them when time.  Never looked at them with the thought of taking them apart.
So how does the top chrome cover piece come off?  How did you compress.
Bill
8Track
« Reply #7 on: December 15, 2014, 02:27:07 PM »
Hey Mark;
Hi there, I just did a search on the Ebay seller's name and the springs are still listed:
http://www.ebay.com.au/itm/DNM-REAR-SHOCK-SPRING-300LBS-20CM-LENGTH-DIRT-BIKE-/170957283695?pt=AU_Motorcycle_Parts_Accessories&hash=item27cdd9216f
And yes the chrome cover fits back on.
To compress them, my mate used an adjustable frame made of angle iron to hold them upright, and compressed them from underneath using a trolley jack. The top shock mount screws off.
The new springs are holding up just great.
Regards,
Mark
« Last Edit: December 15, 2014, 02:28:44 PM by 8Track » Logged
Icelander
Snohomish, WA
« Reply #8 on: December 15, 2014, 08:25:53 PM »
This is the closest I've been able to find in the States:
http://www.afcodynapro.com/AFCO/1956851466
http://www.summitracing.com/parts/eib-08001880300/overview/
http://www.qa1.net/suspension/springs/1-875-id-coil-springs  - Have to plug in the numbers yourself.
Are these the same? I could not find any with the exact dimensions in the other post.
Kendall (Icelander)
1998 Valkyrie Tourer.
VRCC Member #36337
