February 09, 2026, 04:57:16 PM *
Author Topic: where is the thermostat?  (Read 1035 times)
blackvalkyrie
California
« on: December 12, 2014, 12:05:33 PM »
where is the thermostat on a 97 valk standard?
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: December 12, 2014, 12:23:05 PM »
Follow the top radiator hose, behind the radiator, at the other end, it is in the housing on top of the engine block.
Sounds like it's time to get yer paws on a repair manuel.
Good luck.
Black Dog
Don't you know...
Fathertime
Washington County, New York
« Reply #2 on: December 12, 2014, 01:25:21 PM »
Copy that
« Reply #3 on: December 12, 2014, 01:44:37 PM »
Inside the black thing.
« Last Edit: December 12, 2014, 01:47:54 PM by Gryphon Rider » Logged
« Reply #4 on: December 12, 2014, 03:47:38 PM »
A T T E N T I O N - Read carefully.
If you do take it apart, DO NOT over tighten the studs.
Bring them all down to just snug.
Then go around the housing and tighten a little more on each, repeat till ya finally have it to the correct torque.
Also, if you don't follow the instructions on snugging the studs down, you can and will break the thermostat housing, then you go buy a new one, IF the Stealer happens to have one in stock.
blackvalkyrie
California
« Reply #5 on: December 13, 2014, 12:13:11 PM »
thanks black dog!! I'll take your advice to heart... O appreciate it! cooldude
Good luck.
Black Dog
blackvalkyrie
California
« Reply #6 on: December 13, 2014, 12:14:29 PM »
Thanks R.J. will do....
