February 09, 2026, 06:54:51 PM *
Author Topic: STEERING HEAD BEARING REMOVAL  (Read 1179 times)
bentwrench
Philadelphia,Pa.
« on: January 04, 2015, 07:19:56 AM »
Since the weather is so bad I decided to get an early start on my 100k service.I got the whole frt.end off the bike and did the fork seals and bushing with minimal difficulty.when it came to removing the lower steering race I couldn't get it to budge.Tried the allthread and washers I had seen pictured in other threads but this one wasn't moving.After looking at the factory tool in the manual I did a little searching and found this from OTC.http://www.amazon.com/OTC-4796-Steering-Bearing-Remover/dp/B00BVL80JA/ref=pd_ybh_13
Way cheaper than the 99.00$ honda tool.I had to a chamfer around the top to get it to bite in. The top shoulder is too thick as it comes.Once it's snugged up in there the race came out with two taps cooldude
This is worth adding to your tool set even if you only use it once or twice.
Any body in my local vicinity that wants to use it let me know.
« Reply #1 on: January 04, 2015, 07:26:54 AM »
Boy did I ever cheat when I did that... as I remember, this was between
$50 and $70 bucks on eBay  Smiley
I have the Honda tools for the other bearing and race, they just popped out easy
as you please...
bentwrench
Philadelphia,Pa.
« Reply #2 on: January 04, 2015, 07:45:22 AM »
The bearing came off that piece without any trouble,it was the race in the frame that was giving me fits.
« Last Edit: January 04, 2015, 08:36:51 AM by bentwrench » Logged
jimmytee
Elizabethtown,KY
« Reply #3 on: January 04, 2015, 08:01:00 AM »
I'm trying to remember, but I think I cut mine off. Roll Eyes It was a pain for sure.
« Reply #4 on: January 04, 2015, 09:09:44 AM »
I just use one of these, paid about $20 for one about 10" long. Set the angle of the moveable end to almost straight out, just a slight bend in it and lock it down. Slip it in from the top and it will catch on the top of the lower race. A couple good raps with a hammer on one side, turn 180 deg. and repeat. The clink you hear is the race falling on the floor. Easy peasy, got the idea from Daryl at Xf6, works great. It's hardened steel apparently, I've used mine a number of times with no damage to the tool.
http://www.northerntool.com/shop/tools/product_200378689_200378689
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #5 on: January 04, 2015, 11:33:50 AM »
I made a cut in mine with a Dremel. Easy
Have a safe ride
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: January 04, 2015, 11:52:32 AM »
If you weld. make a couple of lines down the race, it will fall out.
« Reply #7 on: January 04, 2015, 02:25:03 PM »
Bearing removal 101, easy
Inside, weld a bead around it like Valker said.
Outside, heat a spot red hot, lay pean end of hammer on it and whack it with another.
« Reply #8 on: January 05, 2015, 06:25:16 AM »
Geez guys, by the time you do all that welding, I'd have mine out and the new one in and left for coffee.  Wink
« Reply #9 on: January 05, 2015, 07:35:42 AM »
Replacing bearings has never been a maintenance item.
To do so is foolish and the occurrence of unintended
consequences persists.
bentwrench
Philadelphia,Pa.
« Reply #10 on: January 05, 2015, 02:18:02 PM »
mine were dry worn and indexed at at 95,000m.She feels like her old self now.
art
Grants Pass,Or
Grants Pass,Or
« Reply #11 on: January 05, 2015, 04:32:33 PM »
A small bead of weld perpendicular to the race will heat up and expand then will cool and shrink and the race will come out easy. As a machinist I've done this many times.
RonW
Newport Beach
« Reply #12 on: January 05, 2015, 06:23:13 PM »
There use to be tons of pics showing that *bead* on the outer races. Anybody know the links?
« Last Edit: January 05, 2015, 06:58:18 PM by RONW » Logged
2000 Valkyrie Tourer
wiggydotcom
Yorkville, Illinois
« Reply #13 on: January 06, 2015, 05:16:20 PM »
Just ordered one of those tools. Thanks for the link, bentwrench!  cooldude
VRCC #10177
VRCCDS #239
