February 09, 2026, 06:54:52 PM *
Author Topic: headlight rim removal  (Read 900 times)
doniholcomb
« on: January 07, 2015, 12:24:04 PM »
I am putting on a tri bar on my headlight (tourer) bt I can not figure  how to removed the rim, I have removed the two small screws that hold the rim on but will not budge, any sggestions?
rhinor61
Northern California
« Reply #1 on: January 07, 2015, 12:33:57 PM »
There are just 2 oval Phillips screws (5mmx12mm) holding on the trim ring.
I think their position should be 4 oclock and 8 oclock...
dont mess with the 2 headlight lens adjustment screws..
Its a tight fit and could need a slight bit of help to come off. I sprayed silicone spray, cover up the fender and let it soak.
Update
suggested by JS "Pull the bottom out first and lift slightly"
I heave gently used a plastic glass trim tool to separate the trim ring from the headlight bucket.
Be careful not to damage either component.
once off, make sure to clean up and use silicone spray to repel moisture..
hope this helps.
J.
« Last Edit: January 07, 2015, 01:28:39 PM by rhinor61 » Logged
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
« Reply #2 on: January 07, 2015, 12:37:22 PM »
Pull the bottom out first and lift slightly, the top of the ring has a small lip on it which you'll see once it's off. If it's been on there for a long time, it can be a bit sticky to pop it loose at first.
« Reply #3 on: January 07, 2015, 12:47:48 PM »
 Yes sir it's been there a long time  cooldude and welded together with grime, dirt and bugs.  2funny
My rides:
BonS
Blue Springs, MO
« Reply #4 on: January 07, 2015, 01:17:22 PM »
After wrestling off the headlight rim off of the headlight case you need only to pry the three tabs that hold the chrome ring onto the headlight unit to remove it. Put the tri-bar in place and then reinstall the chrome ring onto the headlight unit by pressing the three tabs back into place. I really like the way they look.  cooldude
