November 26, 2025, 05:33:00 AM *
Author Topic: fuel tank vent  (Read 1051 times)
brampton6626
rapid river mich
« on: January 08, 2015, 01:40:52 PM »
2000 i/s
 fuel tank vent  has a tee in it   (#2) on diagram, can't find what else hooks to tee beside tank , then to ground. anybody help?   thanks
« Reply #1 on: January 08, 2015, 01:45:11 PM »
2000 i/s
The tee is some kind of vacuum breaker... someone will explain better, and
you can search the board for lots of discussion on the tee...
Daniel Meyer
The State of confusion.
« Reply #2 on: January 08, 2015, 01:46:13 PM »
Nothing else hooks to it. Tank to "T", of the bottom of the "T" to under the bike next to the "Dragon drool" tube, side of "T" left open. It is, essentially, a vacuum break. While you're there make sure the port is clear (and the end of the vent tube under the bike is clear).
CUAgain,
Daniel Meyer
« Reply #3 on: January 08, 2015, 02:02:46 PM »
Well, actually the tank vent winds up near the kickstand (opposite side from the old drool tube)
Daniel Meyer
« Reply #4 on: January 08, 2015, 03:32:38 PM »
Mmmm...my vent hose and drool tube are held in the same bracket under the bike...right side...
CUAgain,
Daniel Meyer
« Reply #5 on: January 08, 2015, 05:05:43 PM »
Same for mine
« Reply #6 on: January 08, 2015, 06:45:45 PM »
are you sure that aint the carb drain tube.
Daniel Meyer
« Reply #7 on: January 09, 2015, 08:53:07 AM »
Yep.
CUAgain,
Daniel Meyer
Rio Wil
« Reply #8 on: January 09, 2015, 11:15:19 PM »
The manual shows the stock location for the vent tube is on the left side by the side stand spring. There is a loop bracket provided to retain the tube.
