November 26, 2025, 05:22:20 AM
Petcock rebuild test
Topic: Petcock rebuild test (Read 673 times)
brampton6626
rapid river mich
January 09, 2015, 12:12:55 PM »
will rebuild petcock tomorrow. will test by
1. screen off of stand pipe, will fill with gas, petcock in off position, no flow thru petcock
2. vacuum line from #6 carb on petcock, petcock in off position, vacuum from mouth no flow
3.petcock in run position, no vacuum , no flow--vacuum on, flow on
4.petcock in res position, no vacuum, no flow--vacuum on, flow on
sound right guys,
Pete
Re: Petcock rebuild test
January 09, 2015, 01:45:26 PM »
Yes.
Screen should not matter.
January 09, 2015, 07:20:00 PM »
You can do the test at the end of this article before you put your bike back together...
http://www.valkyrieriders.com/shoptalk/petcock.htm
=> InZane XXV
