November 26, 2025, 05:36:48 AM *
Author Topic: Wow, all 6 "O" rings leaking  (Read 1477 times)
SpidyJ
Murrells Inlet
« on: January 12, 2015, 01:44:06 PM »
After a 3 or 4 week hibernation I uncovered her and let her run for about 20 minutes.  I had the petcock turned off and have a solenoid inline.  I let her run out of gas before puttin' her up .....pulled the fuse on the solenoid too.
After running for awhile yesterday there was a small puddle of fuel on both heads under each intake.
Hope this job is as simple as it looks.
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: January 12, 2015, 01:59:53 PM »
it is
« Reply #2 on: January 12, 2015, 02:48:15 PM »
original o-rings?
could just be the o-ring sealant leaking out from the long idle hot condition.
next time running, a vacuum leak is indicated by an up and down idle.
da prez
Wilmot Wi
« Reply #3 on: January 12, 2015, 02:58:45 PM »
  Spidy , Get the new O-rings first. Loosen the (hose) clamp above the runner and loosen both bolts and then remove. Lift the runner up and remove the O-ring . Replace and if needed use a touch of stick-um (technical term) to hold O-ring id place. Set runner down and make sure it is flat . replace bolts and torque to specks. tighten clamp . Repeat five times (but on the other runners)Replacing the same one 6 times will not work.
                     da prez
« Reply #4 on: January 12, 2015, 03:39:50 PM »
Go to a local hydraulic supply and get O rings. Size is a #123 and buy Viton material. You won't have to do this repair again.
SpidyJ
Murrells Inlet
« Reply #5 on: January 12, 2015, 03:44:12 PM »
 Original O rings.
original o-rings?
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #6 on: January 12, 2015, 06:19:17 PM »
                     da prez
$6.60 for 25 pieces from McMaster Carr.........now I can put 4 on each intake right Prez!?
Should seal 4X better!!
 crazy2 coolsmiley
Peace,
johnnywebb
« Reply #7 on: January 13, 2015, 03:52:17 PM »
                     da prez
 crazy2 coolsmiley
At this price, they weren't Viton, but you have plenty to change them out again.
SpidyJ
Murrells Inlet
« Reply #8 on: January 13, 2015, 04:34:38 PM »
[/quote]
Hmmmm....
McMaster Confirmation:
Line  Product Ordered 1 9464K87 Chemical-Resistant Multipurpose O-Ring, Viton(R)
 3/32 Fractional Width, Dash Number 123, packs of 25
 1 pack ships in the morning
 $6.60 per pack
Peace,
johnnywebb
« Reply #9 on: January 13, 2015, 05:04:44 PM »
Does anyone know the #`s of the 3 o-rings in the rear wheel & pumpkin ? I`m thinking at those prices I could get 4 lifetimes worth. coolsmiley
« Reply #10 on: January 13, 2015, 06:38:05 PM »
http://www.carolinabikeandtrike.com/ORings.htm
5 sets, $13
« Reply #11 on: January 13, 2015, 08:40:20 PM »
[quote author=SpidyJ link=topic=74867.msg733333#msg733333 date=142119567
I stand corrected!
[/quote]
Hmmmm....
 $6.60 per pack
[/quote]
« Reply #12 on: January 14, 2015, 03:24:38 AM »
Yeah that's where I have been getting them. I thought if I could get 25 sets for $20 or so I'd never need any more.
« Reply #13 on: January 14, 2015, 05:43:52 AM »
Is it possible your fuel rail o-rings dried out and contributed to the puddles you observed?  ???
My rides:
SpidyJ
Murrells Inlet
« Reply #14 on: January 14, 2015, 06:43:35 AM »
[/quote]
Dunno!.....Will find out.
Peace,
johnnywebb
« Reply #15 on: January 14, 2015, 09:00:33 AM »
When mine did gas POURED out of them
« Reply #16 on: January 14, 2015, 10:39:58 AM »
In my experience, once the fuel rail o-rings are bathed in gas they will swell and stop  leaking after about 12 to 24 hrs. They won't leak fuel again until the bike remains idle for an extended period of time.
My rides:
« Reply #17 on: January 14, 2015, 02:27:59 PM »
cooldude exactly what mine did
« Reply #18 on: January 15, 2015, 05:11:01 AM »
It's a good idea to change the O-rings but it will also give you that appearance when the screws work loose a bit.
