dreamaker
« on: January 14, 2015, 06:44:22 PM » |
I just got done building my digital sync tool kit, (By tz89), pretty cool. I have got to find the right enclosure for it yet. Just have to wait for spring, to check it out on the carbs.
Has anyone else built one yet.
« Last Edit: January 16, 2015, 05:07:25 AM by dreamaker »
Jetflyer
« Reply #1 on: January 15, 2015, 06:27:13 PM » |
BIGBF has a digital snyc tool that folks que up in line for hours, to have his services performed at Inzane. Your first good sync job is unforgettable.
« Last Edit: January 15, 2015, 06:31:26 PM by Jetflyer »
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
Tailgate Tommy
Fort Collins, Colorado
« Reply #2 on: January 17, 2015, 06:35:47 AM » |
Dreamaker, I have a retired electrical engineer friend of mine making me one too. I'd be interested in what you use for the enclosure. Tom
dreamaker
« Reply #3 on: January 17, 2015, 06:57:22 AM » |
I am still kicking that around, would like something that looks pro. I wish I was still working, I would vacuum form one up. But I haven't looked hard yet, but maybe a basic project box.
Tailgate Tommy
« Reply #5 on: January 23, 2015, 05:56:38 PM » |
Thanks for the info!
BonS
« Reply #6 on: January 23, 2015, 06:02:42 PM » |
This is really interesting. Roughly speaking, and aside from the labor, about how much will you have in the electronics and packaging altogether?
dreamaker
« Reply #7 on: January 24, 2015, 07:46:46 AM » |
Here is my deal!! I bought twinMax for around $150, then I bought two CarbTunes for $205 and finally MotionPro Sync Tool for $120. These units had limitations, plug in and unplug, must be vertical, special fluid that evaporates and so on. I thought this would be fun to build, a monkey could build one if these, proof is I did. Board was $50, box was $7, sensors were $80(I didn't bother looking for better prices, went to Digi-Key) I think hose is $.08 ft. Close to the price the I paid for the other units, but this I can run off of a bike battery and maybe a 9v battery. This way I can do all cylinders at same time, and to my understanding, the sensors are more accurate then needs to be, with no syncing of unit. Still working on the lid, doesn't look pretty, but functional unit, can almost put it in my jacket pocket. I'll take a pic when done. By the way I sold the other sync tools, except for the MotionPro, so in a sense it is not costing me anything.
dreamaker
« Reply #8 on: January 24, 2015, 10:02:43 AM » |
Here is my pic of the unit close to completion, if you notice the hoses, they go through the cover and pushed on to the sensors. The reason I did this way is to keep the strain off the sensor, the strain is on the hose and cover. I don't know how sensitive or durable the sensors are, I don't know if it is necessary or not, but I have to still put an extension rod to the reset switch. So far so good, all's I need now is springtime.
Tailgate Tommy
« Reply #9 on: January 24, 2015, 10:30:52 AM » |
What did you use for the hoses? Auto parts store regular vacuum hose in 5/32?
dreamaker
« Reply #10 on: January 24, 2015, 10:53:48 AM » |
Auto supply, 1/8" ID rubber hose, the sensors are for 1/8" hose, now lately I have seen that silicone hose, seems more flexible, but I don't know if it would collapse under vacuum. Now the hoses that are coming out of the box are 1/8" X 8" long, but still have to use plastic insert adopter 1/8" to 5/32" to 5/32" hose to carb. I guess there are several ways you could do it, the options would be up to you, on how to set it up. I will probably use suction cups to mount, so it doesn't scratch the tank.
dreamaker
« Reply #12 on: January 25, 2015, 05:45:28 AM » |
BonS
« Reply #13 on: February 09, 2015, 06:29:38 PM » |
robin
Get on it and RIDE!!
Hardwick NJ
« Reply #14 on: February 10, 2015, 02:14:44 AM » |
How much would it be to have some one build one for me
dreamaker
« Reply #15 on: February 10, 2015, 04:55:22 AM » |
That looks Super!!! Love that hose adopter setup. I couldn't find 1/8" to 5/32" adopters, only in kits, one each at $3.99 per kit, so that wasn't going to happen. So I ended up using brass round tubing I got at the hobby shop, and made my own adopters. But I must say, yours are much better, I have never seen any of those before. Where do you get them?? Real nice job!!
dreamaker
« Reply #16 on: February 10, 2015, 05:24:25 AM » |
Good creative use of adopter, medical supply, cool!!! Any way I went to Nordson web sight and found the luer connectors. I assume that series, for example 200 series or 500 series refers to size, if so, what series are you using or model numbers would help. I going to make an order, love to have some of those laying around for future projects.
PS: Figured it out, series is style, they had drawing of the connectors, you have 500 series.
« Last Edit: February 10, 2015, 06:23:41 AM by dreamaker »
Big Rig
« Reply #17 on: February 10, 2015, 05:56:56 AM » |
How much would it be to have some one build one for me  +1
henry 008
BRP
willard, oh
« Reply #18 on: February 10, 2015, 07:03:49 AM » |
How much would it be to have some one build one for me  +1 me too!
Safe Winds... Brother
BonS
« Reply #19 on: February 10, 2015, 07:09:36 AM » |
This eBay auction will get you 25 of the (Value Plastics/Nordson) 1/8" to 5/32" adapters pretty cheap: http://www.ebay.com/itm/151002702026?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITThe other half of my connector comes Ark-Plas.com. It's a one-piece hose-barb male luer. I like it better than the more expensive two piece designs. It can be difficult to find small quantities of these parts. By the way, I had trouble finding 1/8" hose and ended up with 7/64" windshield washer/vacuum hose. It's within 1/64" and fits up nicely.
BonS
« Reply #20 on: February 10, 2015, 07:27:19 AM » |
As for building these kits there are a few things to know:
1) You'll have to PM tz89 to see if more kits are available. 2) Soldering up the components is fast and easy if you have any soldering skills. 3) It really doesn't take any computer skills to program the Arduino. 4) You don't absolutely need an enclosure but if you want one then the carving took the lion share of the time. A Dremel and file is what you need. 5) I'd love to do this for the folks that want one but hobby time is scarce until I retire.
dreamaker
« Reply #21 on: February 10, 2015, 10:01:55 AM » |
I would like to share a few things also, in case someone wants to build one themselves. The container is the most time consuming thing of the project like BonS said. I have no training or background in electronics of any kind, just willing to take on a challenge. If you look at my pic., with the open case it look more complicated than it is, there is a processor board under the sync board, called Arduino clone. You don’t have to build that, you buy it; price is anywhere from $6.99 and up. The sync board you build, it plugs in to that board. The trick I found to soldering is cleanliness; I take Scotch bright pad and lightly clean the foil on the board before soldering (Most people’s problems with soldering is contaminated foils, it may look clean, it may not be). Far as soldering the sensors, rather than using solder coil, I used solder past, made it quick and easy, the rest I used solder coil (solder on the roll). I didn’t use the hot plate method, I used a RadioShack soldering iron, I just bought an extra tip, and ground a small flat spot on an angle at the tip, and that worked fine. Board should take about 15-30 min to finish. Go for it!!
tz89
« Reply #22 on: February 10, 2015, 02:15:34 PM » |
I just got a new batch of boards in the mail today. I'll be doing a 6 sensor build this weekend and will post a picture. If you want a board PM me.
tz89
« Reply #23 on: February 13, 2015, 05:17:21 PM » |
dreamaker
« Reply #24 on: February 17, 2015, 08:42:04 AM » |
Here is a little update for me, on my unit, thought could helpful to the people building one. http://www.kjmagnetics.com/categories.aspOverview just to get an idea!! If you noticed the length of the hose I didn't make them to short, if you make them too short they get stiffer, this way they stay flexible.  Here are two close-up of the connectors. This great idea is courtesy of BonS   Here is a shot of the bottom of the unit, see the four rubber bumpers and the two magnets, note the magnets have elect. tape on it .  This is the magnet I used, got it from the sight above. K&J!!  Note the gap, the magnet never touches the flat surface, or in our case the gas tank. The rubber bumper are slightly higher than the magnets. Got the bumpers at RadioShack. By the way you don't have to use a flanged case to use the magnets, just screw the magnets from the inside of the case.  Another thing I did, I used some spark plug wire separators I had lying around, to stabilize and minimize loads on the sensors itself.
« Last Edit: February 17, 2015, 08:48:54 AM by dreamaker »
tz89
« Reply #25 on: March 07, 2015, 10:08:10 AM » |
Have you hooked it up to your bike? I'm anxious to hear (and see some pix).
Thanks.
