November 26, 2025, 05:50:03 AM *
Author Topic: trike fuel mileage  (Read 1313 times)
Trike Man
« on: January 17, 2015, 04:52:07 AM »
I have an 01 Valkyrie with a Motor Trikes conversion. In town, I can get around 125 miles before hitting the reserve. On the highway, I can get around 100 (90 if I'm really having fun) before hitting the reserve. I've been thinking about options to increase mpg or cruising distance. Does anyone have any thoughts on tire size to increase mpg or maybe an auxiliary tank? Motor Trikes does not offer a factory made aux tank.
« Reply #1 on: January 17, 2015, 06:08:42 AM »
You don't state whether you have a standard or a tourer or an I/S. The I/S has the larger STOCK tank. Having triple digit fun on my I/S I hit reserve in 100 teenish miles. And it's NOT triked-YET. These 6 carbs get VERY THRISTY when yer havin fun. It ALL depends on yer right hand!  Roll Eyes RIDE SAFE.
Gideon
Indianapolis, IN.
« Reply #2 on: January 17, 2015, 06:54:38 AM »
Trike Man: Your mileage is the same as mine. I have a 2003 Standard with a C/S Trike Kit.
I bought the bike new and triked it two years latter.
« Reply #3 on: January 17, 2015, 07:45:03 AM »
There is a auxiliary tank available for these Phat girls.
Here is the link.
http://www.rmworksinc.com/Information.html
Farther
Quimper Peninsula, WA
« Reply #4 on: January 17, 2015, 08:27:55 AM »
The RM Works belly tank mentioned above is an engineering marvel in my opinion.  I've have one on my Standard for about five years.  Unobtrusively mounts between the frame rails and does what it's supposed to do without additional effort after installed.
~Farther
3W-lonerider
Shippensburg Pa
« Reply #5 on: January 17, 2015, 05:46:08 PM »
R&m belly tank will not work on a valk with a motortrike kit.  it will not fit under there with the way the ladder bars are designed. that's what I was told by r&m when I inquired about one.. as far as mileage goes. you lost 5 mile per gallon when it got triked. you get more mileage around town because you don't have the wind drag on those fenders when riding slow.
Trike Man
« Reply #6 on: January 19, 2015, 04:52:59 AM »
My Valk is a Standard. The belly tank won't fit on the trike due to the ladder bars mentioned by 3W-lonerider. Was curious about getting taller tires to see if this will help. Has anyone with a trike tried this? I am also considering fitting an auxiliary tank where the rear tire used to be. They make them for CSC but not Motor Trike.
old grouch
Colorado Springs, CO
« Reply #7 on: January 19, 2015, 06:09:05 AM »
FWIW.  When I triked my Interstate I lost about 5-7 mpg on the highway.  Taller tires (larger diameter) will lower your RPM at any given speed.  How much depends on how much larger the diameter is.  I have no idea what would be the largest tire you could fit in there.  My guess would be that you might be able to lower the RPMs at the most by 100-200 with tires alone.  If your tires are due for replacement, buying taller would make sense.  Replacing nearly new tires just to lower RPMs, not so much.  Here is a link that will give you some info about tire sizes.  You can do the math to see how much RPM difference you can get.  http://ejelta.com/tiresize/index.html?tiresize=150%2F80-17&minwidth=&maxwidth=&minratio=&maxratio=&minwheel=&maxwheel=&maxdelta=2  Stock final drive gearing  on a Valk is 2.83:1.  I don't know what gears you have in the diff, but if you can get to 2.73:1 (biggest ring gear that will fit into a 7.5" Ford which is what I think M/T uses) that would give you about a 100-200 RPM reduction as well.  I did the math on that years ago but can't remember what it came out to.  Having said that, the question is whether the cost of the diff gear change (if you can even find them) would increase your mpg enough to pay for itself.  If you were able to achieve a full 400 RPM reduction, you could run about 70-75 mph & be below the 3000 RPM "magic" number where the carbs start to pull fuel through the mains.  Other than the right wrist, the biggest factor is added wind resistance with a trike.  The faster you go the greater the wind resistance.  The added weight, about 400 lbs or so is also a major factor.  Hope this is of some use.  Stan
09/11/01 NEVER FORGET!
DK
Little Rock
« Reply #8 on: January 19, 2015, 06:49:08 AM »
My '2000 Valk standard is triked with the Lehman Preditor kit. (small & light weight)
I hit the reserve usually at 100 miles, less if I'm really having fun in the mountains, more on flat and open roads that I try to avoid.
I am not complaining. I'm having a lot more fun per mile than getting 12mpg in my Landcruiser.
DK
Little Rock
« Reply #9 on: January 19, 2015, 06:52:23 AM »
