November 26, 2025, 05:35:46 AM *
Author Topic: DO NOT TRY THIS !!!  (Read 1286 times)
Bone
« on: January 17, 2015, 06:27:57 AM »
              POSSIBLE CT MOUNTING METHOD
The TV show on the Science channel "Outrageous acts of Science" showed a
guy with a new drive wheel tire mounted to a large earth mover.
The vehicle was jacked up high enough to install the wheel with the tire on the
rim/wheel.
The guy squirted starting fluid in the tire. Picked up about a 5 ft. long stick with
one end on fire. Waving the fire around the open tire a small fire started the guy
stepped back. Maybe 15 seconds later the fire expanded and the tire popped
seating it's self.  It holds about 200 lbs. pressure when inflated.
« Reply #1 on: January 17, 2015, 06:48:48 AM »
I've never done that but have seen it used a number of times, especially on the farm. Just about any flammable stuff with a quick ignition like that will work. Even saw one guy swipe his wife's hairspray, sprayed the inside and lit it up. Poof....bead seated. He had his wife watch and she got a bit upset when she saw it was her hairspray. Even more so when it ignited.  Grin
« Reply #2 on: January 17, 2015, 07:18:12 AM »
Easiest way to do it when in the fields on a tractor. Seen my uncle do it many times. Works nicely if you got the balls to do it.
« Reply #3 on: January 17, 2015, 07:33:35 AM »
When I worked in the tire shop the truck tire mounting area had a can of ether right there with the large tire irons and inflation cage. In the case of ether-LESS is MORE. Git carried away and you WILL hurt equipment and people. 11X24.5 tubeless took 2 little squirts and wave the lighter over it. I have lost some arm hair at times!  Roll Eyes RIDE SAFE.
« Reply #4 on: January 17, 2015, 07:35:25 AM »
Done it on my Bobcat several times.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: January 17, 2015, 08:31:02 AM »
It's crazy to watch but effective.
http://youtu.be/0K1V00yUe6o
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #6 on: January 17, 2015, 04:17:36 PM »
Saw it done on the trail for those hard core 4x4ers, after they spin a tire off the rim that was under inflated to get a better grip on the trail.
There was also a cross the artic expedition doing the same thing. Over sized tires at 5lbs air. Easy to spin off the rim. Just as easy to remount. Bang and pop. Lots of youtube videos on the subject.
« Last Edit: January 17, 2015, 04:24:12 PM by gordonv » Logged
matt
Derry New Hampshire
« Reply #7 on: January 17, 2015, 04:54:32 PM »
Yup did that for years when I was an off road mechanic.  Big thing to also watch when using anything flammable you have to make sure you do not inhale any of the gases as when you light tire if you are close you could actually in jest the fire into your lungs not good at all lost a guy years back he burnt his lungs pretty much cooked from the inside. Do I still use it yup but user beware I guess
« Reply #8 on: January 17, 2015, 06:17:18 PM »
I operated earth movers for 6 years and have seen this trick many times. If you think that is bad try having one of them tires blow up under your ass. I was in an old open cab cat 637B and the tire under my ass blew and folded the fender straight up only a couple inches from the back of my head. Loved running those things though. Eventually got upgraded to pan foreman and put in a brand new G model with radio and AC.
Grandpot
Fort Mill, South Carolina
« Reply #9 on: January 18, 2015, 10:15:24 AM »
Seating a tire bead with ether works great.  It is one of those 'right of passage' to be handed down from father to son.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #10 on: January 18, 2015, 12:37:30 PM »
Never done it but seen it done. I like this because he cracks a beer before he starts......what should always be done before an attempt of this type  Grin
How To : Fire Bead Lock Tire Seatingpowered by Aeva
