November 26, 2025, 05:36:17 AM *
Author Topic: Steering neck bearings help  (Read 633 times)
old grouch
Colorado Springs, CO
« on: January 17, 2015, 07:03:31 AM »
Not having much luck with the Search lately.  I know I saw a thread on this subject recently but can't find it.  So can anyone tell me if 1) there are replacement bearings/races for the steering neck other than OEM Honda  2)  what the part number(s) for them is 3) do the OEM Honda bearings come with the races?  TIA Stan
09/11/01 NEVER FORGET!
« Reply #1 on: January 17, 2015, 07:28:35 AM »
All bearings come with new races.
The bearings in the steer head have a # on them, any good bearing place can get you a replacement bearing.   I've never tried it on a part # for a replacement.   Ya might get the part # for the EOM and call a bearing place to see if they can interchange it.
I never looked in http://www.jkozloski.com/generic_parts.htm here for a replacement, so take a look 1st.    Also save this link it is worth it's weight in Gold.    I've used it many many many times.
old grouch
« Reply #2 on: January 18, 2015, 05:19:36 AM »
Thanks, RJ.  Stan
longrider
Vernon, B.C. Canada
« Reply #3 on: January 18, 2015, 06:29:31 AM »
http://www.partzilla.com/parts/detail/aftermarket/XP-4102743.html
I just replaced mine.   Easiest way to remove the lower race is to weld a short bead on it.  It'll drop right outa there.
Warren
