November 26, 2025, 05:35:53 AM
shimmy?
Topic: shimmy? (Read 658 times)
Farther
Quimper Peninsula, WA
shimmy?
January 17, 2015, 08:39:54 AM »
Since changing my front tire from a Metzger to a Bridgestone, I have had a low speed handlebar shake/shimmy while decelerating down a slight incline like an off ramp. I recently had installed a new set of Avons and have the same shake/shimmy but less that I had with the Bridegestone. I never noticed this with the Metzger but that could be just a coincidence. I have check nothing; what should I check?
Last Edit: January 17, 2015, 08:45:48 AM by Farther
~Farther
Re: shimmy?
January 17, 2015, 09:12:04 AM »
Did you put a new rear on? If the rear cups it will make the shimmy you are feeling at low speed and go away when up to higway speed.
Farther
Re: shimmy?
January 17, 2015, 09:15:24 AM »
New Avons front and rear. Even with these new Avons I am getting the humm when cornering at speed like I did with worn Dunlaps.
Last Edit: January 17, 2015, 09:17:01 AM by Farther
~Farther
Re: shimmy?
January 17, 2015, 09:16:54 AM »
Hmmm.
Tfrank59
'98 Tourer
Western Washington
Re: shimmy?
January 17, 2015, 10:19:25 AM »
Quote from: Farther on January 17, 2015, 08:39:54 AM
I just went from a worn-out Metzler to a Bridgestone, and everything is great. I can't think what that would be except bad balancing?
-Tom
Keep the rubber side down. USMC '78-'84
Steve K (IA)
Cedar Rapids, Iowa
Re: shimmy?
January 17, 2015, 01:21:10 PM »
What should you check?
Kind of sounds like how my I/S was handling about 9 years ago. Would get a wobble/shake when decelerating through the 40 mph range. Had the stearinghead bearing checked...needed an adjustment, tightened and all okay. That's the first thing I would check.
States I Have Ridden In
Re: shimmy?
Reply #6 on:
January 17, 2015, 04:45:01 PM »
Check your rear shock bushings. Should be dead center when you remove upper bolt. If NOT dead center you have a culprit!
RIDE SAFE.
Attic Rat
VRCC # 1962
Tulsa, OK
Re: shimmy?
Reply #7 on:
January 18, 2015, 06:43:58 AM »
Tighten up the steering head bearings. they are too loose.
=> InZane XXV
