February 09, 2026, 08:57:17 PM *
Author Topic: Front end loose  (Read 877 times)
Firefighter
Harlingen, Texas
« on: January 19, 2015, 11:03:28 AM »
I discussed with you guys about a month ago as how my 2000 IS felt loose in the front end during slow speed maneuvering, how when I turned it felt like steering bearings were loose. I still have the front fairing off and today had time to play with the bike again. I took the front wheel off and notice when I hold the fork slider with one hand and the fork tube with the other I can get movement, can wiggle them back and forth if you will. Not much but a definite sloppyness in both forks like maybe a bushing is wore. I have no experience with working on forks, my main question is, should there be any slop there? It feels like enough to cause my loose problem.
Just checked again and the left fork seems way more noticeable than the right, also the left is easier to push in than the right. Had a sorta friend and motorcycle mechanic install new progressive springs, sliders?, seals, and oil about 12,000 miles ago??  opinions please  Thanks Firefighter
« Last Edit: January 19, 2015, 11:05:21 AM by firefighter » Logged
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #1 on: January 19, 2015, 11:08:27 AM »
It needs new bushings in the forks.
« Reply #2 on: January 19, 2015, 11:25:07 AM »
 cooldude Most likely!   Undecided  I would also make sure the volume of fork oil is correct.
« Last Edit: January 19, 2015, 11:26:58 AM by salty1 » Logged
My rides:
« Reply #3 on: January 19, 2015, 12:10:28 PM »
But even dry there shouldn't be play in the fork slider within the tube. I would also check the torque value on the steering head bearing.
Firefighter
Harlingen, Texas
« Reply #4 on: January 19, 2015, 02:10:31 PM »
I am readjusting the head bearings now. Think I will try and overhaul the forks, never done that before!
Thanks for response,, Firefighter
1978 Honda 750
uturn
bayou vista, texas
« Reply #5 on: January 19, 2015, 05:06:12 PM »
if you want some help with forks, i will be in hebbronville every weekend the rest of the month for work...i can drive down and help. its a pretty fun and rewarding job.
Firefighter
Harlingen, Texas
« Reply #6 on: January 19, 2015, 05:57:42 PM »
Wow Uturn! That's too cool!  I need to order parts, and will try myself first I guess, as I have done most everything else myself, just never worked on forks before. My make shift shop lacks a vice which I probably will have to get, right? I also never know how much time I can devote at any one time. But if I mess up or can't figure it out maybe I can come your way. Hope to start having more time to play in the future.  Thanks so much, Firefighter
1978 Honda 750
bentwrench
Philadelphia,Pa.
« Reply #7 on: January 20, 2015, 03:13:31 PM »
If you're not swapping the springs the fork bushings and seals are a piece of cake.search utube for valk or vtx fork bushings and you'll find a few tutorials that shows how easy it is.It's bit more work  to swap the springs but I think it was worthwhile.
