February 10, 2026, 02:21:10 AM *
Author Topic: Motowings  (Read 3047 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: January 25, 2015, 02:34:07 PM »
Just ordered my Motowings , hope they are everything they're supposed to be.
Can't wait to find out.
Correction guess I have to wait Grin
Signed,
Patiently waiting
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
BonS
Blue Springs, MO
« Reply #1 on: January 25, 2015, 04:13:13 PM »
For a Standard or Interstate? I have both and have had continuing trouble with cracking on the Interstate. Not Motowings though, they're Baker Built. I'd love to know if Interstate Motowings fare any better.
NewValker
VRCC# 36356
Oxford, MA
« Reply #2 on: January 25, 2015, 05:02:55 PM »
BonS, did the wings crack? or the pods where they attatch?
Wewaman, sorry for the hijack,
Craig
Turns out not what or where,
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #3 on: January 25, 2015, 05:21:28 PM »
No problem with the hijacking,  cooldude
 I'm married and,,,,, well,  just used to it 2funny
 I have an 03 Standard
Wewa
Kep
My "Mid-life Crisis "
Indiana
« Reply #4 on: January 25, 2015, 05:23:11 PM »
I have the flame cut motowings on my standard Bakers and they are fantastic...not a hint of cracking or anything.
BonS
Blue Springs, MO
« Reply #5 on: January 25, 2015, 05:25:32 PM »
BonS, did the wings crack? or the pods where they attach?
Craig
The upper wings crack. I knew in advance of pod cracking so I added an additional support to the chrome bar support. You can see the zip tie support and a new star crack appearing at the mounting hole. This is the second set and they're beginning to fail the same way and now it's just a matter of time. I tried to avoid over tightening the screw at that hole. After the first set failed I attached these with kid gloves - fail! I'm looking for another supplier that makes a better, stronger upper wing for the Interstate.
I've never had any issue with my Standard wings except for the lower balls loosening and falling off - OF MY AIRWINGS!
big poppa pump
San Antonio, TX
« Reply #6 on: January 25, 2015, 05:40:53 PM »
Got my panels custom made by motowings. Rik was very helpful and prompt to answer any emails right from concept to fabrication. The acrylic used for the panels is definitely thicker than the original ones from baker.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
BonS
Blue Springs, MO
« Reply #7 on: January 25, 2015, 06:53:04 PM »
Motowings are definitely better looking than Baker. I'll give them a call and see if their IS panels will fit the Baker frames. I'm not throwing away any more money on Baker. Thanks!
wingrider02
Maple Lake, MN
« Reply #8 on: January 25, 2015, 07:35:20 PM »
BonS, they certainly do fit the baker frames....I put them on my IS....baker frames with smoked Motowings.  From what I could learn, the frames Motowings offer are Bakers.
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #9 on: January 25, 2015, 10:10:07 PM »
Why don't you make them yourself with lexan. I did it on my I/S using the old ones as template.Easy job.
Have a safe ride
« Reply #10 on: January 26, 2015, 03:55:54 AM »
Yes, MotoWings uses Baker frames. Rik has permission and support from Baker. Motos are 3/16" vs 1/8" for Bakers. I have Rik's smoked hand wings on my 1800 Wing.
BonS
Blue Springs, MO
« Reply #11 on: January 26, 2015, 05:48:44 AM »
I've never worked with Lexan. Doesn't it require special cutting blades and drill bits? How does the heat and bend process go?
Signed,
Patiently waiting
And yes, they're everything they're supposed to be. I love scooping in extra cooling air in the summer and extending my riding seasons by blocking the cold winds. All with an easy adjustment while I'm riding. I know - "Don't adjust them while riding! (Baker)".
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #12 on: January 26, 2015, 06:06:42 AM »
No special tools required. Go to youtube and you will find everything. I used a table saw to make the first cuts. Then used a belt sander to form the contour. A regular wood bit will be good for the holes and finally a heat gun to bend. Watch the video for the finishing touch on the edges using sandpaper and a torch
Have a safe ride
« Reply #13 on: January 26, 2015, 02:23:49 PM »
The original panels that came with my set of Bakers cracked within a year.  They actually started to fall apart not long after that.
Baker sells replacement wings/panels that are much better that don't crack.  Mine have been on there for years now with no problems.
BonS
Blue Springs, MO
« Reply #14 on: January 26, 2015, 03:14:51 PM »
They have "Next Generation" wings with stronger plastic for the Standard but not for the Interstate.
Tfrank59
'98 Tourer
Western Washington
« Reply #15 on: March 06, 2015, 09:55:42 PM »
Craig
I'm waiting on air wings – Moto wings – to come from Rik for my 98 tourer.  Do you think putting some Loctite on those lower balls to keep them from loosening up (and falling off) is a good idea in hindsight?  Based on what I've been reading in this thread, it seems like don't over tighten anything, but a little Loctite to keep everything from vibrating apart might be a better plan.  What do you think?  Thanks.
-Tom
big poppa pump
San Antonio, TX
« Reply #16 on: March 07, 2015, 07:53:21 AM »
I did not use any loctite and mine has never loosened. I do occasionally inspect them and if needed hand tighten them. If you are going to use loctite use the green kind.
VRCC#35870
VRCCDS#0266
BobB
« Reply #17 on: March 07, 2015, 11:20:59 AM »
I lost one of those ball nuts years ago and replaced them with a chrome acorn nut.  So a little blue Loctite would not hirt.  I prefer adjusting with a wrench anyway.
I have also replaced the Baker panels with Moto-Wings after going through two sets of Baker's.  The Moto-Wings are, hands down, superior.  Half again as thick and a better material.
« Reply #18 on: March 07, 2015, 01:00:09 PM »
Carolina bike and trikes makes metal ones  cooldude
http://www.carolinabikeandtrike.com/Deflectors%201.htm
Tfrank59
'98 Tourer
Western Washington
« Reply #19 on: March 07, 2015, 06:21:56 PM »
Isn't the green loctite the high strength/high temp?  I was thinking the red stuff I got that's easy to break loose if I want to.
-Tom
BonS
Blue Springs, MO
« Reply #20 on: March 07, 2015, 07:17:45 PM »
Tfrank59
'98 Tourer
Western Washington
« Reply #21 on: March 07, 2015, 07:37:08 PM »
Well alright then. cooldude
-Tom
« Reply #22 on: March 08, 2015, 07:19:19 AM »
I just ordered a set of motowings and big bike things fork deflectors for my IS. I guess BonS fix with the zip tie is the best bet to keep the pods from cracking. I still like the idea of stainless bar stock of both sides of the pod for extra reinforcement.  And some blue loctite to keep parts from fall ing off.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #23 on: March 09, 2015, 03:34:59 PM »
Well got my Moto's and they look and work great. cooldude   But after a couple weeks of riding and checking I am now minus 1 ball  tickedoff so I will replace with an acorn nut and Definitely use loctite on ALL the nuts.
GREAT ADVICE  cooldude
Wewa
Tfrank59
'98 Tourer
Western Washington
« Reply #24 on: March 09, 2015, 10:31:53 PM »
Wewa
Okay this is going to sound weird, and I guess I'll find out in a few days when my stuff shows up, but what exactly do those "balls" do?   Cheesy. And if they can be replaced with acorn nuts, why does Baker supply balls?
-Tom
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #25 on: March 09, 2015, 10:54:04 PM »
The balls are just round nuts that are easy to adjust by hand.  And baker says to keep checking them but  If you heed the advice about using some loctite you won't have any problems.
Tony
« Reply #26 on: March 10, 2015, 05:58:22 AM »
I ordered my Motowings on Saturday, never have heard anything from them about my order. I got the dark smoke tint with the flame design. How long did it take you guys to receive yours after ordering?
big poppa pump
San Antonio, TX
« Reply #27 on: March 10, 2015, 07:51:08 AM »
Mine took a while since it was a custom design.
VRCC#35870
VRCCDS#0266
Tfrank59
'98 Tourer
Western Washington
« Reply #28 on: March 10, 2015, 08:00:55 AM »
Yeah, I already received the panels from Rik, but the mounts are coming from Baker, and I haven't got a tracking number or anything – I hope they come this week.  I don't even know how to check on them except through Rik. crazy2
-Tom
« Reply #29 on: March 10, 2015, 08:25:01 AM »
just got an email back, said the panels would be built today and said Baker was sending a batch of brackets to chrome today. so i may be another week before i see the brackets.
Tfrank59
'98 Tourer
Western Washington
« Reply #30 on: March 10, 2015, 09:03:30 AM »
looks like you ordered IS mounts which are different than tourers so maybe mine are en route. Cheesy
-Tom
big poppa pump
San Antonio, TX
« Reply #31 on: March 10, 2015, 09:30:52 AM »
Support from Baker sucks!!! When I ordered replacement parts from Baker after my accident, they screwed up the order TWICE even after I called and spoke to them on both the occasions. They did not send me any tracking info either, I had to call and request it.
VRCC#35870
VRCCDS#0266
Tfrank59
'98 Tourer
Western Washington
« Reply #32 on: March 10, 2015, 10:14:12 AM »
Well, you gotta wonder how they like furnishing their mounts for Motowings anyway.  I know it's more product out the door for them, but it's still like they lost business to Rik and probably just a matter of time before they say you get everything from us or nothing.  Angry
-Tom
« Reply #33 on: March 10, 2015, 10:44:42 AM »
They probably get a decent deal on the mounts when they buy in bulk but make most their money on the plastic wings.
« Reply #34 on: March 11, 2015, 02:25:32 PM »
Just recieved another email from Rik at motowings and said the Baker IS brackets are at chrome and the turn around is 4-6weeks. Said this is the first time this has happened since they have been dealing with them. I think it's great Rik lets his customers know the status of their purchase. He wanted to return my money and let me reorder when they became available.  Told him I could wait and thanks for keeping me in the loop.
Tfrank59
'98 Tourer
Western Washington
« Reply #35 on: March 11, 2015, 08:05:28 PM »
Thanks for the heads up – sorry your stuff's delayed.  I just emailed him and asked for an update, if he has one, on brackets coming from Baker for my tourer.  Maybe I'll get lucky.
-Tom
Tfrank59
'98 Tourer
Western Washington
« Reply #36 on: March 12, 2015, 08:46:56 PM »
Well, my stuff arrived today from Baker, and they totally botched my order. tickedoff  They did send the correct mounting brackets for a Valkyrie tourer, but they omitted most of the hardware.  I don't see how anybody on their end could imagine I'd be able to mount panels with what they sent me.  Sucks. So now I have to work through Rik to get my order from Baker straightened out.  The only good news is he  reassured me that if something wasn't right, he'd make it right.
-Tom
timmyba22
« Reply #37 on: March 12, 2015, 11:59:55 PM »
Just put my Dragon MOTO Wings on my tourer. Baker hardware. Live in Palm Springs, CA and the engine heat can be brutal in summer temps of 110+. Have adjusted them in several different angles and the work better than I even hoped for. Good luck with yours
DK
Little Rock
« Reply #38 on: March 13, 2015, 08:35:15 AM »
Tony
I've used loctite since puberty, but have never before come across the green "wicking" version. Will someone please tell me about it?
Has anyone heard of loctite or a like product that comes in stick form? My brother says he saw some being used by dirt track racers last year?
Although the balls make a great knob, I thought they were also like handlebar weights - to minimize vibration & keep the things from coming apart like they always do.
Tfrank59
'98 Tourer
Western Washington
« Reply #39 on: March 13, 2015, 04:01:25 PM »
Tony
Yeah, I have a couple of "sticks" of Loctite – it works pretty good on most applications, and the stuff I have is red;-)
-Tom
