July 15, 2025, 07:55:05 AM *
Author Topic: replace timing belts  (Read 890 times)
brampton6626
rapid river mich
« on: January 26, 2015, 05:11:22 PM »
removed cover tonight, will pull spark plugs tomorrow, turn motor over to  make sure all timing marks line up, then pull tensioners, put belts on , adjust tensioners,turn motor over a few times to check marks once again. hope it goes as easy as manual reads. any thoughts guy, sure appreciate the help.
thanks  guys
« Reply #1 on: January 26, 2015, 05:48:34 PM »
thanks  guys
You will need to remove (un bolt) the ignition module pick-up thingies.  Before you do...use a sharpie and put an X on one (top or bottom) so you are sure which one goes where when you put them back on.  After the bolts are out you still have to pry them suckers off because the mounting flange is designed to go inside the holes to maintain the gap to the timing wheel.
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #2 on: January 26, 2015, 06:39:02 PM »
Check the tensionners springs. Don't put them back in inverted position (upside down)
Don't forget to put sealer on one of the cover book (covered in the manual )
Pretty easy job
Have a safe ride
