December 20, 2025, 01:30:01 AM *
Author Topic: Some months really Suck  (Read 1698 times)
Grumpy
Tampa, Fl
« on: January 26, 2015, 08:52:42 PM »
Jan has not been my month, started with me screwing my back up, then my son under going surgery. Then my house decided it was time to work on it, had to replace the drain field. Got that done, now cutting a trench through the concrete slab in the house to run new sewer lines under it. The old cast iron pipes started coming apart inside. I sure hope next month is better. Cripes I just need to get out and ride.
« Reply #1 on: January 26, 2015, 09:31:49 PM »
I'm with you Bill.
Just pulled some back muscles (or moved around some bulging disks) getting out of my (broken but still serviceable) recliner.  A real manly injury.
It's bad enough the old body is letting us down, but it just seems unfair the old house is going right along with it.
The cast iron pipe from my kitchen sink drain thru my (cracked) slab has moved/bent (or had tree roots thru it) for years, and been power routed out a number of times, but if it ever fails, I have to jack hammer the slab/floor, or run PVC thru the walls.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: January 27, 2015, 03:09:59 AM »
Bill, if I know you your cutting that trench yourself with your back injury. I'm available this weekend if you need help. It could be a win/win for me. Hard labor can help me with my mid section reduction program cooldude
Grumpy
Tampa, Fl
« Reply #3 on: January 27, 2015, 05:02:00 AM »
I am not doing most of it, we hired a guy from our church that is doing most of the labor. Renting a concrete saw tomorrow, and cutting a 1 x 10 foot trench in the floor to replace the pipe, then re-pouring the slab. Thank you for the offer Doug. I will be glad when this mess is done with.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: January 27, 2015, 08:09:33 AM »
Yup its a mess. We went through it last month, but not as bad. Ours was outside and accessible. Roots had crushed the clay pipe where it connects to the city sewer system. Used a rubber boot  to connect and replaced with PVC. We dodged a bullet. It was just passed the pool deck (concrete) still an unexpected pain in the butt. Todd and Pennie have gone through this recently too.
Best of luck Bill. Hope it goes well.
« Reply #5 on: January 27, 2015, 11:34:29 AM »
"Slap a Fernco on it!"  cooldude
-Mike "something I heard plumbers say..."
Grumpy
Tampa, Fl
« Reply #6 on: January 27, 2015, 01:11:03 PM »
I wish I could, most of my problems are where it comes up out of the ground and branches out. The pipes are peeling inside, cast is separating internally so only option is to replace it. At least  when I finish every thing will be pvc. But sadly most is under the slab, so have to dig it out no matter what I do.
reclaimerroger
« Reply #7 on: January 27, 2015, 01:57:16 PM »
Sorry you have been having such a lousy month Bill.
Hopefully by the time the repairs are made you will be good enough physically to ride.
BCoy
Valrico, Florida
« Reply #8 on: January 27, 2015, 02:49:00 PM »
Bill, I am available as well if you need some help digging an trenching. I can take orders to if you need some cleanup help putting everything back in its place.
« Last Edit: January 27, 2015, 02:51:27 PM by BCoy » Logged
Grumpy
Tampa, Fl
« Reply #9 on: January 27, 2015, 04:38:37 PM »
Appreciate the offer, but I have a handle on it. Most is dug up, just have to cut the slab for 10 ft. Renting a concrete saw Friday to do the cutting, then I can get the pipes laid and cover it up.
FloridaValkRyder
Apopka, Florida
« Reply #10 on: January 28, 2015, 03:13:50 PM »
Wish I had a nickel for everyone of those I have sold..
I still miss her.
« Reply #11 on: January 28, 2015, 05:04:21 PM »
Is that some kind of bargain ED device?   Roll Eyes
Grumpy
Tampa, Fl
« Reply #12 on: February 02, 2015, 06:44:00 PM »
Well finally finished running all the plumbing. replaced every thing under the house, even had to remove toilets and put new flange connections in the floor. I now have a fully functioning system. Now just have to put all the dirt back, and pour some concrete. Finally be finished this week. Then have to rework the driveway where we removed the pavers for the drain field. Sure be glad when it is finished.
« Reply #13 on: February 02, 2015, 09:40:41 PM »
That looks like a genuine PITA.
Good place to hide the evidence (or body parts).  Grin
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #14 on: February 03, 2015, 02:46:54 AM »
  A functioning plumbing system is a good thing to have cooldude  I enjoy heat and AC too Wink
Nice job, that should last you a while Bill. I'll bet you have concrete dust everywhere.
« Last Edit: February 03, 2015, 02:49:55 AM by Tundra » Logged
Grumpy
Tampa, Fl
« Reply #15 on: February 03, 2015, 05:29:57 AM »
Thank fully just that room, still a pita to clean up.
