July 15, 2025, 08:05:32 AM
Fuel problem
Topic: Fuel problem (Read 632 times)
JDWhite
Nashville, TN
Fuel problem
January 27, 2015, 04:03:04 PM »
Went to start my Valk on Sunday after not being started for a few weeks. She didn't want to start and I had to hook up jumper cables. After several starts then stalls.. I finally got her running. With the choke all the way on it was still idling very low. I revved her up to get the engine warm and I noticed smoke coming from the motor and smelled gas. I saw that fuel was leaking out and hitting the pipes and smoking.
The only thing I can think of is that the carbs were flooding and overflowing?
Has anyone else had this happen?
1998 Valkyrie Tourer "The Beast"
GPz1100
Texas
Re: Fuel problem
January 27, 2015, 04:32:36 PM »
yeah. mine was a bad o-ring 'tween the carbs.
Re: Fuel problem
January 27, 2015, 05:18:55 PM »
Yes, usually after a day or so of having gas on the o-rings they will swell up and seal again.
Re: Fuel problem
January 27, 2015, 08:55:48 PM »
It also sounds like the enricher is not engaged the whole way.
You know to turn it till it stops, then push it another 1/2 inch or so. It will be very hard, but this is the 6 slides moving.
=> InZane XXV
