January 29, 2026, 11:56:09 AM *
Author Topic: Ragnar Cut - Before & After.....  (Read 2487 times)
« on: August 22, 2009, 11:05:06 AM »
For those that might be curious as to what the Ragnar Cut will do, or, how it sounds...here's a before and after video.
Before Ragnar Cut (piggies had been cut and the rear baffles had been drilled)......
Honda Valkyrie - LED turn and tag light modificationspowered by Aeva
And after the Ragnar Cut (rear baffles have been removed)......
Honda Valkyrie - after Ragnar Cutpowered by Aeva
You may not get a full sense of just how big a change that the Ragnar Cut provides listening to the two videos, but it IS a big change.  It is deeper, louder, and more rumbly sounding.  If you want to go Harley Huntin' on the cheap, this mod will do it for you.
art
Grants Pass,Or
Grants Pass,Or
« Reply #1 on: August 22, 2009, 01:49:11 PM »
sounds good but where did you get the led light on your license tag plate?Art
« Reply #2 on: August 22, 2009, 02:17:17 PM »
Here......
http://www.customdynamics.com/knight_rider_led_light_bar.htm#Knight_Riderz_LED_License_Plate_Frames
22Dasher
Shelbyville, TN
« Reply #3 on: August 22, 2009, 03:27:20 PM »
I have the rear and front baffles drilled on my Tourer, If I do the Ragnar cut will I need to shim the carbs?
James
« Reply #4 on: August 22, 2009, 05:00:44 PM »
If I understand it correctly, cut piggies, you won't need to shim.  Cut piggies and rear baffles drilled, you won't need to shim.  Ragnar cut, you won't need to shim.
Cut piggies & rear baffles drilled  +  drilling the front baffles, yes, you need to shim.
Ragnar Cut  +  drilling the front baffles, yes, you need to shim.
I could be wrong, but the way I understand it is.....you don't need to shim unless you've drilled the front set of baffles.
http://www.valkyrieriders.com/shoptalk/Pipes101.htm
http://luiscajiga.com/Exhaustm.htm
http://luiscajiga.com/Exhaustm2.htm
"Shims, springs and other carb things"......
http://www.rattlebars.com/mtz/shims.html
