November 26, 2025, 06:27:00 AM *
Author Topic: clutch not holding?  (Read 904 times)
bsg
naples
« on: February 04, 2015, 05:05:43 PM »
Hello All,
I have a '98 F6, after having new tires installed  the clutch after maybe 10-20 seconds seems to not hold ? it shifts fine but while holding the clutch in it try's to take off , Any one down this way know of a good mechanic and or have a possibly fix .
Thanks for any input Scott
« Reply #1 on: February 04, 2015, 05:27:50 PM »
Start with looking over the clutch lever, and see if the pivot pin is warn, therefore not engaging fully.
The second is has there been a recent oil change? Wrong oil, different, etc.. could be slipping.
« Reply #2 on: February 04, 2015, 05:30:25 PM »
It might help if you tell us where "down this way" is.
Can't see where changing tires would have any connection.
Have you changed your engine oil lately?
Have you checked the clutch fluid in the master cylinder?
« Reply #3 on: February 04, 2015, 05:33:17 PM »
Air in system, low on hydraulic fluid, wrapped plates, oil level too high, wrong viscosity, etc according to the service manual.  Undecided
My rides:
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #4 on: February 04, 2015, 05:57:06 PM »
Check Oil level
If low check for a leak
Maybe the slave cylinder is leaking and not holding the clutch compressed
Have a safe ride
« Reply #5 on: February 04, 2015, 06:57:36 PM »
First: Flush and bleed the clutch fluid. Use a good quality DOT 4. If it still "creeps" rebuild the master cylinder.
PharmBoy
Lawton, Ok
« Reply #6 on: February 05, 2015, 09:01:05 AM »
Have you changed to after market clutch/brake levers? That was my problem once upon a time...Jim Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
big poppa pump
San Antonio, TX
« Reply #7 on: February 05, 2015, 09:19:36 AM »
Had this issue on my '98 when I first bought it. Turned out to be the slave cylinder. Rebuilt the slave and all issues were resolved.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #8 on: February 05, 2015, 02:17:30 PM »
I agree with Sandy, it's the master cylinder needing to be rebuilt.
bsg
naples
« Reply #9 on: February 05, 2015, 04:48:06 PM »
Thanks All,
The fluid was changed when the tires were installed at the Honda Shop way down in Naples Fl. took it back  was bleed a couple of times, bought a rebuilt kit for master cylinder took to a different shop in have installed and still creeps ? now at a third shop and hoping this guy can get it right. So does anyone know of a good mechanic ?  So if the second guy did install and rebuild the master cylinder could be slave cylinder? since it was fine before the Honda shop. So any one know of a good mechanic Way down here in Naples Fl.
Thanks Again
« Last Edit: February 05, 2015, 04:53:20 PM by bsg » Logged
« Reply #10 on: February 05, 2015, 04:49:49 PM »
Read big Pooppa Pumps  post.
bsg
naples
« Reply #11 on: February 05, 2015, 04:54:59 PM »
yep, Thanks
« Reply #12 on: February 06, 2015, 08:50:47 AM »
How the level in the master cylinder is, would reveal which is having the problem
If it's the master cylinder leaking the level will remain constant.
If it's the slave cylinder leaking the level will diminish.
Observe and learn, it's not rocket science.
