February 09, 2026, 10:40:20 PM *
Author Topic: Starter button / Headlight connected  (Read 1202 times)
ValkISDan
Forest Lake, MN
« on: February 07, 2015, 05:22:40 PM »
If I take apart the starter button will it solve a problem I'm having with an intermittent headlight? It seams if I engage the starter button a few times when the headlight isn't working I can get it to come on.  tickedoff
« Reply #1 on: February 07, 2015, 06:50:59 PM »
In the shoptalk section, you'll find instructions on how to clean the starter button contacts.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: February 08, 2015, 08:55:30 AM »
Yes, the start button is integrated in headlight circuit.  When you press the starter button, it disconnects the headlight to keep load off the system (known as "off while cranking.")
As suggested, clean the starter switch contacts.
You should also install a relay in the headlight circuit to protect the starter switch from overheating.  Use Rattlebar's "Start Switch Safeguard" shown on this page: http://www.rattlebars.com/valkfaq/circuits.html or use this diagram: http://www.barnettdh.com/Valkfiles/HLDLdualrelayST.pdf and disregard the driving lights side of things (unless you've got driving lights or are going to add them.)
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #3 on: February 08, 2015, 11:14:14 AM »
The IS model already is relay driven.
Valkpilot
Corinth, Texas
« Reply #4 on: February 08, 2015, 03:38:06 PM »
Sorry.  Failed to notice it was an Interstate.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #5 on: February 08, 2015, 08:52:28 PM »
The rest still applies.
Except for adding a relay to the IS.
Valkpilot
Corinth, Texas
« Reply #6 on: February 09, 2015, 06:50:33 AM »
If non-OEM driving lights will be added to an IS: http://www.barnettdh.com/Valkfiles/DLrelayIS.pdf
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
