March 14, 2026, 07:04:40 PM *
Author Topic: Switching back to stock pipes  (Read 4190 times)
Safety Steve
« on: February 08, 2015, 11:01:24 AM »
I got a set of Beetle bags and I tried to mount them but they won't fit because I have Super Trapp exhaust on my bike, so I'm going back to the stock exhaust, when I bought the bike the Super Trapps were on it, my question is when I go back to stock do I have to reject the carbs?
Thank you for help
Steve
« Reply #1 on: February 08, 2015, 11:51:48 AM »
Steve this is posted in the 180-0 tech board I think you may have a 1500 if it has carbs.
« Reply #2 on: February 08, 2015, 12:05:24 PM »
Thank you for help
Steve
That is a question the general public here can not answer correctly just by reading your post.
I had Super Trapps on MGM twice.    1st time I did not have to rejet.
The 2nd set I mounted them, it needed to be rejetted real bad.
Put the stock pipes on it, and take numerous readings of the plugs.
If they are not a nice light tan/gray color after a good aggressive ride, yes, you will need to rejet.
Read the plugs out on the highway if possible.     Run it in the 70 to 90 area, don't get a costly slip of paper doing this.
Run it for a couple of miles at speed, pull the clutch in, shut the key off and put the transmission in neutral.   Roll to a stop, with the dead engine.    Pull a couple or 3 plugs and check for the light tan/grayish color on the plugs.
Here is a link to reading plugs.
http://ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
Have fun. cooldude cooldude
