March 11, 2026, 01:52:04 PM
No brake lights with front lever or rear pedal
Topic: No brake lights with front lever or rear pedal (Read 1120 times)
robdurn
Chicagoland
August 22, 2009, 05:09:24 PM »
On my standard 97 Valk, all the sudden I'm getting no brake lights. Nothing by hand or foot. The tail light works. The fuse and bulb filaments look good. Could it be a break switch? Easy fix? Thanks.
-Rob
Illinois
shortleg
maryland
Re: No brake lights with front lever or rear pedal
August 22, 2009, 05:18:52 PM »
I would check bulb with VOM.
Also check wires at rear with same.
There are two switches, one at pedel
and one at lexer.
Shortleg[Dave]
Capt. Morgan
Midlothian, IL , Portage, IN
August 22, 2009, 05:23:01 PM »
See if your horn works. There are 2 fuses 1 for tail lights and 1 for brake lights. If no horn, fuse is blown
Capt. Morgan
1999 Valkyrie Interstste
The "Fast Black Type"
August 22, 2009, 05:56:18 PM »
I worked on a Valk for a friend who had no brake lights. Front or rear. Thought a fuse (nope); loose/broken wires (nope). Stumped for a few minutes. Found the front lever switch was faulty, Cleaned/lubed switch; so I got br. lights working. Pedal still didn't work. The spring connecting the pedal to the rear switch was gone. Who'da thunk 2 problems with brake lights at the same time.
August 22, 2009, 08:21:45 PM »
Change the bulb first thing....its a dual filament......different flame for running lights and brake lights
