February 10, 2026, 12:38:31 AM *
Author Topic: Antifreeze drip  (Read 1176 times)
santa
Santa Tom
Ardmore, Alabama
« on: February 12, 2015, 08:44:34 PM »
 Found a drip of antifreeze on the floor after I had run the bike for about 5 min. Started it up again a couple days later and couldn't get it to leak again. Am I going crazy or what? The bike had not been run for a couple months before this.
Santa
« Reply #1 on: February 12, 2015, 10:12:06 PM »
Upper hose clamp on the upper radiator hose-usually. Be CAREFUL when you go to tighten that clamp. RIDE SAFE.
Brian
Monroe, NC
« Reply #2 on: February 13, 2015, 04:35:20 PM »
Look close at the top of the engine. I found the hose clamp on the thermostat housing a little loose once. If it is coming from under engine there are two pipes with special tapered rubber 0-rings that are pressed into the block, one on each side. These are what the top hose off the water pump connect to. Then I also had the radiator cap leaking. Bending the tabs a little bit to tighten the cap fixed that issue.
Onetime during a rad flush and fill with fresh anti-freeze I filled the rad more than normal reducing the air space at the top. This then forced the cap to lift as designed to put excess pressure into the reservoir. The over flow hose connection at the bottom of the container was leaking. Further inspection of the overflow bottle revealed that the OEM reservoir hose connection was never open to the bottle. An 1/8th inch drill bit took care of this issue.
Good luck.
Firefighter
Harlingen, Texas
« Reply #3 on: February 14, 2015, 03:12:14 PM »
My Interstate did the same and it was the upper radiator hose clamp. With the bike on the side stand the drip was in a strange place. I ended up leaning the radiator forward to get to mine. I didn't like the narrow clamp, looked like it might cut the hose so I changed it out to a wider one and positioned the clamp so I could hopefully reach it next time with out loosening the radiator.  Firefighter
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #4 on: February 15, 2015, 08:34:01 AM »
Since each radiator hose has two clamps, one on each end it is misleading to
simply state the leak is the upper radiator hose clamp because there will
be some who will simply start cranking down on the hose clamp at the
filler neck, possible destroying that part of the radiator.
The hose clamp that most commonly is associated with leaking  is the lower clamp on
the upper radiator hose. This clamp is behind the radiator and information to access
that clamp has already been described in previous posts.
Faulty information is worse than no information at all.
DK
Little Rock
« Reply #5 on: February 15, 2015, 09:13:34 AM »
See extensive thread same subject about one month ago.
Firefighter
Harlingen, Texas
« Reply #6 on: February 16, 2015, 12:55:21 PM »
I agree, don't crank down on the radiator hose clamp screw at the thermostat or the lower connection of the upper hose if it don't leak. Sorry!
« Last Edit: February 16, 2015, 01:02:40 PM by firefighter » Logged
1978 Honda 750
« Reply #7 on: February 16, 2015, 10:34:55 PM »
My upper radiator hose clamp on right side behind the radiator cap on my I/S has leaked a few drips from time to time leaking down the front of the huge chrome timing chain cover just to the left of the horn assembly.  I haven't messed with it yet since have to take off the right I/S pod to readjust or re-tighten, but if it gets worse, I will have to.
It seems to happen over winter for me or when the bike sits idle for more than a few weeks I get a tad bit of seepage from that area.  If ridden weekly,  I don't see the leak then.  I'm tempted though to put 2 metal hose clamps up there one where it is at now which is in about 3/4" from the end and put another one at the very end of the rubber hose itself. Not sure if needed, but can it hurt???
Firefighter
Harlingen, Texas
« Reply #8 on: February 17, 2015, 05:06:05 AM »
If it is a straight nipple I wouldn't think it could hurt, If the nipple has a raised end to keep the clamp on I wouldn't clamp it there. When I replaced the hose clamps on my IS, the factory clamps were very narrow and I used automotive clamps which were wider. I think over time with all the heating and cooling cycles the hose and clamp tend to loosen and drip. Don't tighten the clamp so much that the hose stretches out, just snug a little more. My opinion only.  Firefighter
1978 Honda 750
« Reply #9 on: February 17, 2015, 08:21:46 AM »
Actually, the best thing to do before tightening the hose clamp would be to
loosen the hose completely freeing it from the pipe and cleaning the connection,
both the pipe and the inside of the hose. I don't think many would do that however.
The second good thing to do would be to loosen the complete hose clamp around the
whole circumference and lubricate it before tightening it.
Now some may take exception to this little step, but I tell you
that you chance destroying the tightening ability of the clamp by deforming the threads
cut into the band and also are not guaranteeing that you will equally tighten around
the whole circumference of the hose by omitting this simple step.
A little common sense will go a long way when dealing with a small leak from a coolant hose.
Do it right and get it right.
Firefighter
Harlingen, Texas
« Reply #10 on: February 17, 2015, 10:56:25 AM »
I have found over the years that snugging the clamp is best. If you remove the clamp, it is best for the hose, to put the clamp back in the same location. My experience is with automobile hoses. Firefighter
1978 Honda 750
