January 29, 2026, 05:04:14 PM *
Author Topic: MS Batwing Fairing  (Read 4077 times)
KW
West Michigan
« on: August 22, 2009, 08:13:53 PM »
Can you get the MS Batwing WITH a radio? Or, is there space to fit one? Does anyone have a Valk Standard wiht a MS Batwing and radio? Thanks!
DFragn
« Reply #1 on: August 23, 2009, 03:45:34 AM »
No.
You'd have to rig something up and I imagine that would mean fastening through to the exterior. Although some chrome acorn nuts may not look too awful depending on positioning.
I have the RadioCaddy fairing. If http://www.woodysfairings.com/aboutus.html had been available when I did mine I would have saved a ton of customizing & $$$.
I have a Sony head unit and pipe the GPS audio directions, Garmin MP3 & XM through it and tie it all in with the Hondaline CB to the headset. All but the CB pumps through the Polk Audio Momo marine 5.25" speakers.
RadioCaddy Interior
Exterior
« Last Edit: August 23, 2009, 03:53:21 AM by DFragn » Logged
KW
West Michigan
« Reply #2 on: August 23, 2009, 08:22:27 AM »
I went to the link. .. . (thanks) I have to say; that's a GREAT looking faring AND a fantasic price, but the 'relocating' the gauges makes me hesitate. Do the gauges have to be moved on the Memphis Shade batwing? The fit does look better on the woodysfaring (IMO) but the MS looks nice too. If only I would have got an Interstate 8 years ago  Cheesy
DFragn
« Reply #3 on: August 23, 2009, 04:09:40 PM »
To my knowledge "No" no relocation of gages with MS fairing. But then no tunes either!
Woody's fairing does require relocation just as my RadioCaddy fairing did.
Relocation requires a 6" speedo extension and between the 2 gages there is 21 wireing extensions needed (recommend they're soldered).
Woody's site has some brackets [link] to mount the gages, but they're expensive. I used Kuryakyn "P" clamps and fabricated simple brackets 1.5" x 1.25" aluminum flat bar that polishes up nicely.
It's not that much work if you want the tunes.
If you want more info let me know.
dreamaker
Harrison Township, Michigan
« Reply #4 on: August 23, 2009, 06:26:30 PM »
I also went with the RadioCaddy. I had to get the speedo cable extension but I didn't have to extent my wires.  For the gauges I used the P-clamp and small alum. blocks, made them in my garage. No regrets, love it.
Dan
DFragn
« Reply #5 on: August 23, 2009, 07:58:36 PM »
Dan
Hey Dan,
On electrical extensions. The difference is probably due to our different routing of the gage harnesses. Or it could have been simply overkill to busy myself cause I like to solder tiny tiny wires 42 times.  Grin
Was that detail day? Looks like a fresh coat of wax!  Cool
TheBear
New Jersey
« Reply #6 on: September 05, 2009, 03:45:24 AM »
Try this link for Speedo / Tach relocation.  http://www.xf6-custom.com/tachometer.html
The tach wires will make it.  Speedo cable from Motion Pro is about $ 60 in stainless.  I believe the figure with stock risers is 43 1/2"
I opted for the Hoppe Quadzilla, sold the stock Hoppe speakers and installed 4 - 5 1/4" across the front with an ARC KS125.2 (140 Watt Amp)  I can hear tunes loud and clear with TBR 6 into 6.  You'll need 4 speakers across the front and a good amp to hear it when cruising.  I putzed around and wasted good money with a bunch of half-a** crap until I did right.  You can't beat the ARC KS125.2, it kills.  It has the ability to hurt your ears, even over the 6 into 6 exhaust.
Disco
Republic of Texas
« Reply #7 on: September 05, 2009, 07:20:36 AM »
Here's one that, according to the gentleman working with Des at Ultimate Seats at InZane IX whose Valkyrie was on display, does not require speedo or tach relocation.  It was REALLY nice.
http://www.wideopencustom.com/dotnetnuke/
« Last Edit: September 05, 2009, 07:23:18 AM by Dave in Frisco (TX) » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
007
Low and Lean
Dallas, TX
« Reply #8 on: September 05, 2009, 03:57:57 PM »
2 quick things ... the Wide Open fairing is plastic, while the Hoppes or Woody's fairings are fiberglass, I have the Woody's Fairing and love it.  The biggest difference between the 2 is that Woody's headlight opening is made for the Valk, the Hoppe is made for the VTX and requires moving the Valk headlight up and out because the opening is smaller.
Also, xf6 relo kit includes a longer speedo cable, so you don't need to order one.
Woody and Daryl are great to work with, they are both Valk pilots and understand us and the bike.
Just my $0.02,
007
Roger Moore
VRCC #1209
President
Texas Grand Chapter
Widows Sons MRA
Sodbuster
« Reply #9 on: September 06, 2009, 06:47:58 AM »
WOW .... that Woody fairing looks awesome and a good price to boot !!  My Valk has pullbacks for the handlebars .. do you know if that would be good or bad ??
VRCC # 30938
ssober
Oklahoma
« Reply #10 on: September 06, 2009, 09:39:18 AM »
mine is a wide open customs.  I used a kenwood marine head unit and polk audio speakers.  I dyna matted the entire inside then used carpet behind the speakers then i used poly fill for better sound.  I don't see why fiberglass is any better than abs.  Most mc plastic fenders and I think the valk side covers are abs.  I did not relo my gauges.  I did however have to get a $35 headlight extension and lifted the headlight up and out.http://i83.photobucket.com/albums/j314/ssober/016.jpg[/img]]http://i83.photobucket.com/albums/j314/ssober/017.jpg[/img]]
Some do.
Some don't.
I Did!
Live your life so when your feet hit the ground in the morning, the devil says "crap, he's awake"
judd
VRCC# 13453
B.C. Canada
« Reply #11 on: September 06, 2009, 06:31:07 PM »
Very Nice................ssober,  where did you get the extended Headlight Bracket from? I need one as well.
