February 09, 2026, 11:02:00 PM
Dragon Drool Tube Mod
Topic: Dragon Drool Tube Mod (Read 1020 times)
Gideon
Indianapolis, IN.
February 21, 2015, 08:10:24 AM »
Go to ACE hardware or a plumbing supply store and purchase a 1/2" X 3/8" nylon barbed fitting with a threaded head. Get a lightweight brass or plastic cap to fit on the threaded head if a cap was not supplied.
Slide the existing clamp up the puke tube and remove the plastic plug and clamp. Place a slightly larger clamp on the tube and insert the barbed end of the nylon fitting into the puke tube. Slide the new clamp over the barbed end of the new fitting.
Trim the barbed end of the nylon fitting if it is longer than the plastic plug. Otherwise it will hang further down than original setup.
Now, when you get ready to drain the tube, just unscrew the cap. No need to bother with moving clamps and pulling plugs!
But they that wait upon the Lord shall renew their strength; they shall mount up with wings as eagles; they shall run and not be weary; they shall walk, and not faint. Isaiah 40:31
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
Re: Dragon Drool Tube Mod
February 21, 2015, 09:38:42 AM »
Sounds like a lot of work for no problem. I remove the clamp with my 2 fingers and pull the plug for a second. Reinsert and slide clamp back in place. No tools required. YMMV
Last Edit: February 21, 2015, 11:03:53 AM by KY,Dave (AKA Misunderstood)
February 21, 2015, 09:45:39 AM »
Don't mix that stuff with good scotch or even bad moonshine.
I don't care what anyone says............ it's not that good. Patuooy!
