November 20, 2025, 12:14:27 AM *
Author Topic: What brand of spot light?  (Read 2477 times)
Printer Mike
Eatonton, Georgia
« on: August 23, 2009, 11:38:46 AM »
These seem fairly dim. I can't find a name on them. Would like to upgrade the output, if possible.
Thanks for any help/advice...
Never give up!
junior
new hampshire
« Reply #1 on: August 23, 2009, 01:49:09 PM »
looks like a cobra with a visor that should take a wagner 4 1/2 bulb get a set of 55 watters
Printer Mike
Eatonton, Georgia
« Reply #2 on: August 23, 2009, 02:31:55 PM »
Thanks, junior! cooldude
Never give up!
DFragn
« Reply #3 on: August 23, 2009, 03:33:09 PM »
Wanna see like never before in the dark?
These fit perfectly (4.5") in the Cobra shells.
Wagner/GE H7604 - 100,000 candlepower 12 volts, 50 watts, 3.9 amps. Spot bulb beam: 7° wide and 5° high.
These are used as Piper landing lights as well as marine applications.
For motorcycle road use I strongly suggest you aim them in a criss-cross pattern and you'll never get flashed.
With the criss-cross pattern each spot will then also light up the opposing curve while leaning.
And, this pattern will only be experienced as a quick flash to oncoming traffic, not even long enough to dilate their pupils.
I've used them for about 5 years in my Cobra's and once I criss-crossed them I have never been flashed, not even by Cops.
Careful though. You shouldn't need to pay more then $20.00/ea., Napa sometimes tries to get $45.00/ea.
« Reply #4 on: August 23, 2009, 06:58:40 PM »
I have Cobras and a friend has the ones you have. They're not Cobras. Maybe Sophies lights. Probably 30 watt incandescent bulbs.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #5 on: August 23, 2009, 07:16:17 PM »
DFragn, I looked at your link. They list those bulbs as only 100 hour life expectancy. Has this been on your bike long enough to either prove or disprove this? I run my lights a LOT and this would require me to replace them about once a month if it is accurate.
Thanks for your help.
DFragn
« Reply #6 on: August 23, 2009, 07:36:37 PM »
Well, let's see. I've had mine in play for at about 45k miles and at a conservative average speed of say 45mph that divvies out to 1,000 hrs. 10x so far and don't seem to have even dimmed. I run them all the time for daytime visibility & the occasional night time deer hunting.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: August 23, 2009, 08:05:44 PM »
Thanks, looks like it's good to go then.
« Reply #8 on: August 23, 2009, 09:25:34 PM »
Here is another option.
Currently, I have the ones in the picture in mine.  Oh, been in there for close to 230,000 miles, so I really don't think they are short life bulbs....
When ever they burn out, I'm going to get these.
More light for less draw on the battery.
GE H7616 they only use 36.5 watts and put out 70000 CP. Lights up the road very well.
http://www.atlantalightbulbs.com/ecart/nw012104/GEH7616GENERALELECTRIC.htm
Printer Mike
Eatonton, Georgia
« Reply #9 on: August 23, 2009, 11:37:21 PM »
Thanks for the tips! I have a lot to learn and I really appreciate the help...
Never give up!
Jay
« Reply #10 on: August 24, 2009, 02:21:14 PM »
That looks like the Rivco light bar.  I have them on mine, have not had to replace yet.  Check their site.
woefman
Arizona
« Reply #11 on: August 25, 2009, 06:24:48 AM »
To Be Clear you have Cobra Lights and this is what you use as a replacement Bulb ?
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
DFragn
« Reply #12 on: August 25, 2009, 01:49:48 PM »
Yes, that's the Cobra bars with their supplied cheap tractor lights. And these H7604's are 4.5" bulbs and should fit any housing specifying a 4.5" bulb.
woefman
Arizona
« Reply #13 on: August 25, 2009, 09:59:44 PM »
WOW Sweet Thanks a Million
and
ArmyValker
Richland, MO
« Reply #14 on: August 29, 2009, 03:02:24 PM »
Just installed the H7604's... WHAT A DIFFERENCE! Best upgrade ever!
Plug and play install BTW...
DFragn
« Reply #15 on: August 29, 2009, 04:39:54 PM »
Cool...KingBee turned me on to those.
Did you cross the beam pattern out in front?
ArmyValker
Richland, MO
« Reply #16 on: August 29, 2009, 05:24:45 PM »
Yep  cooldude
