February 09, 2026, 11:00:34 PM
Clutch problem
Topic: Clutch problem (Read 734 times)
Bonzo
Clutch problem
February 22, 2015, 12:31:25 PM »
The temp hit 38 so I rolled out the bike, started it up, let it warm up Squeezed the clutch, engaged first, it lurched and stalled. Clutch fluid was down real low. Took of the Switch top (it was on real tight) Filled the fluid and closed. I could not build up pressure. I could see no leaks and the Fluid lines move when you squeeze the clutch, put there is no clutch. Any ideas?
Woops, I'm sorry.
Re: Clutch problem
February 22, 2015, 12:36:12 PM »
Air in the line. Not sure what to tell you about where the fluid went, but you need to bleed the system
Bonzo
Re: Clutch problem
February 22, 2015, 12:39:58 PM »
researching that now, Thanks!
Woops, I'm sorry.
