February 10, 2026, 12:36:15 AM *
Author Topic: rear shock question for the valkyrie  (Read 1218 times)
LTD
« on: February 22, 2015, 05:48:01 PM »
Going with progressive 412 heavy duties as replacements for the oem rear shocks. What size was oem? was it 13 inch? let me know.
TJ
Lake Placid , Fl.
« Reply #1 on: February 22, 2015, 05:48:54 PM »
yes...
Lazy
Member 31297
Tiplersville, Ms
« Reply #2 on: February 22, 2015, 07:26:28 PM »
I put the 412 heavy on and got a VERY rough ride , had to send them back to be softened up.
Since the Lord is directing our steps, why try to understand everything that happens along the way.
(paraphrase from Proverbs 20:24)
Kunkies
Charlotte, NC
« Reply #3 on: February 23, 2015, 03:36:00 AM »
how much do you weigh Lazy?
Also, although I agree stock rear shock length is 13", I just mounted 2 - 12.5" Progressive Heavy Duty (HD) 444's on my Valk' Tourer and height from the floor to the rear fender was identical to stock.  Sag was also identical; or 3/4".
-Stock shock rear spring load adjustment setting = 3
-Prog' HD 444' rear spring load adjustment setting = all the way up, softest setting.
I'm 5'10", with a 32" inseam; 185lbs wet
Ride two-up ~ 20% of the time.
Woton
Central North Carolina
« Reply #4 on: February 23, 2015, 08:00:04 AM »
From the Progressive Suspension website...
Notes
•Heavy Duty Applications are recommended for riders that are 250lbs or more or for riders who ride 2 up over 50% of the time.
Give due consideration to whether one or both of these apply in your situation, Scott.
"Ride Smart - Ride Safe"
LTD
« Reply #5 on: March 08, 2015, 07:46:31 AM »
Finally got the progressive 412 heavy duties on and wished I had done this five years ago its like a new bike.
