August 11, 2025, 07:35:07 PM *
Author Topic: Reserve tank  (Read 1268 times)
bigjohn531
« on: February 26, 2015, 12:02:41 PM »
Found out the hard way that my tank does not have reserve. Is this a common prob.,and is there an easy fix????????
Grumpy
Tampa, Fl
« Reply #1 on: February 26, 2015, 12:12:38 PM »
If it has the stock fuel valve, I would say it is bad. Inner seal letting the gas bypass from both feed tubes in the tank.
Flrider
Jack
Kissimmee FL
« Reply #2 on: February 26, 2015, 01:16:42 PM »
might want to check and make sure the selector knob was not on reserve already, things get switched around sometimes
« Reply #3 on: February 26, 2015, 01:42:31 PM »
There is no reserve tank.  Reserve is a function of the petcock.  The OEM petcock is famous for failing like this, then you rebuild it and it fails again, even worse ways........replace it with a good piece of equipment.  I put in a non vacuum Pingel and have never regretted it.  Flows plenty of gas and has never malfunctioned in 6 or 7 years
bigjohn531
« Reply #4 on: February 26, 2015, 05:53:26 PM »
Could you give me a heads up on this pingel???????
Grumpy
Tampa, Fl
« Reply #5 on: February 26, 2015, 07:20:47 PM »
You can get one on Amazon, this one is the correct one for the Valkyrie.
http://www.amazon.com/Pingel-Power-Flo-Petcock-Forward-1311-CH/dp/B000GZHZ48
bigjohn531
« Reply #6 on: February 27, 2015, 12:16:09 PM »
Thanks for the info. Do you think I need the kit that they say goes with it?????????
Grumpy
Tampa, Fl
« Reply #7 on: February 28, 2015, 09:29:29 PM »
Nope, the valve I sent the link to is all you need.
bigjohn531
« Reply #8 on: February 28, 2015, 09:41:10 PM »
Thanks Grumpy
