February 10, 2026, 12:36:06 AM *
Author Topic: This carb cure just might work!  (Read 1103 times)
Jeff K
« on: March 02, 2015, 06:31:00 PM »
I spent a lot of time rebuilding my carbs on my Green I/S when I got it, I also added a filter and an electric valve and disabled the vacuum petcock. Problems solved... Right? Well I put it on the lift to do a list of things that still needed to be added and or maintained. So there she sat, for months. So yesterday I decided I'd better fire it up and let it run for a bit. Surprise! It was too late. It wouldn't start, when I did get it started it would only idle on full choke any throttle and it would die. I was mortified that I may have to do this all over again. I drained the carbs and the fuel looked Ok but it was running right. After a while it would run on the throttle without the choke but it wasn't running very well. I stopped and got some Techron and ran it for a while, on the lift. No joy, it still had one cyl that was dead.
Here is where I get creative.
I drained the offending carb's bowl, put a line on its drain and blew compressed air up through it. I could hear air come out the air box but it didn't help the problem. So plan B went into effect. I closed the drain and started the bike, locked the throttle at about 2K rpm. While it was running with the bowl full of fuel I pressurized the hose going to the bowl and cracked the drain open. Viola!! The bike bogged down from the extra fuel, but cleared up fast and now it runs fine!! I could picture the sprinkler going on inside the carb in my mind, the added restriction of the fuel made the pressure more likely to clear all the passages instead of taking the path of least resistance.
I'm so happy I didn't have to tear it down again.   Grin
TJ
Lake Placid , Fl.
« Reply #1 on: March 02, 2015, 07:17:50 PM »
hotvalkyrie
"How ya do-in?"
Singer Island, Florida
« Reply #2 on: March 03, 2015, 04:39:24 AM »
Very creative, wanna clear my carbs...been sitting for 4 years...haven't tried it yet.
My bike has only 4,000 miles on it when it got neglected.
I WILL bring it back to life.  Hope I have as much good fortune as you!
Ocean Surf Motel, Singer Island, FL  Owner
dragonslayer
palm bay fl.
« Reply #3 on: March 03, 2015, 07:20:55 AM »
Sounds like a good idea ,but would like to know how much air pressure you used.
2k IS
98 Tour
2001 Stand
Pappy!
Central Florida - Eustis
« Reply #4 on: March 03, 2015, 02:41:24 PM »
Well, join the club. Have done that before as well with similar results. For some reason it doesn't seem to work as well with the carb bowl dry. My Magna carbs got that treatment.
For reference purposes I used around 100PSI. Sounds like a ton but its going through a tiny drain hole.
Jeff K
« Reply #5 on: March 03, 2015, 03:31:54 PM »
I too used 100 psi.
I figured the worst that could happen is the hose would blow off the drain.
« Last Edit: March 03, 2015, 06:25:57 PM by Jeff K » Logged
bentwrench
Philadelphia,Pa.
« Reply #6 on: March 03, 2015, 03:38:41 PM »
Back in the old days we would take a car that had been sitting a long time that would start but idle rough or only on one barrel.Remove the idle screw and squirt some gum cutter in there follow by full shop air in the idle screw hole,more gum cutter and put the screw back.Fixed a lot of old cars that way.
