February 10, 2026, 12:36:08 AM *
Author Topic: Interstate fairing wiring ?  (Read 845 times)
Dark
Charlotte, NC
« on: March 06, 2015, 07:17:15 AM »
My 99 Interstate has an always on cigarette lighter in the fairing. I want to modify it so that is only on with ignition on. I also have a voltmeter to install.
My initial thought is to use the hot wire (10 amp inline fuse) for the always on cigarette lighter as power input on a relay and then output the lighter and voltmeter from the relay.
Am I on the right track?
If so, what can I tap in to in the fairing to trigger the relay when ignition is on?
If not on the right track can someone offer up an alternate idea?
Thanks in advance
Mike O
Charlotte, NC
Dred
Houston, Texas
« Reply #1 on: March 06, 2015, 04:35:35 PM »
Yes, you are on the right track.  I would tap the running lights for the relay's signal.
Dark
Charlotte, NC
« Reply #2 on: March 06, 2015, 06:19:25 PM »
Thanks, was hoping to get it done tonight but it's to cold in the garage. Maybe tomorrow night.
Mike O
Charlotte, NC
Dark
Charlotte, NC
« Reply #3 on: March 07, 2015, 06:31:05 AM »
I was gathering up needed tools & parts this morning and came across a 4 circuit fuse block I picked up to use for wiring up the GPS mount & auxillery lights on my old Beemer.
Now I'm thinking of using this so with one relay I can wire up the gps, USB outlet, & powerlet outlet ( replace) the cigarette lighter.
Sound like a reasonable plan?
Anything I may not be taking into consideration ?
Looks like it will warm up enough in charlotte today to get a ride in then tackle this project this eve
Mike O
Charlotte, NC
Dred
Houston, Texas
« Reply #4 on: March 07, 2015, 08:33:45 AM »
If you're going to run 4 power leads ... a fuse block might make sense.  I would use it if I had circuits with different power demands which I wanted to protect with fuses.
As long as the power tap for the cigarette lighter is sufficient ... ~12g ... you shouldn't have a problem powering the accessories you mention through a single 10A fuse.  The variable is whatever you might plug into the powerlet ... a cigarette lighter draws heavy, but most 12V accessories powered by a powerlet do not draw nearly has heavily.
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: March 09, 2015, 08:05:23 PM »
I have a 6 point fuse box attached to a piece of 1/4 plywood along with a power point and a couple of USB ports under the seat behind the battery. It powers my GPS, Ipod and cig lighter, as well as my Danmark fuel valve and voltmeter.
I runs off the battery thru a relay triggered by an accessory wire. I used a circuit tester to find a wire that is only hot with the key in Run, one hot with the key in Aux and one hot in both positions.
Fred.
VRCCDS0237
