February 10, 2026, 12:40:16 AM *
Author Topic: Changing over Interstate to LED bulbs  (Read 910 times)
72cutlassdude
99 Super Valk VRCC 35563
Laingsburg, MI.
« on: March 08, 2015, 12:00:40 PM »
So, I want to change my I.S. turn signals, brake light (super valk), and dash lights over to LED. The bike is equipped with the Signal Minder self cancelling turn signal kit with all of the options hooked up. It is my understanding the SM will handle the LED bulbs without any diodes or the like installed?
After looking through Super Brights web site I selected the following bulbs: 1157 LED Bulb - Dual Intensity 3 x 2 Watt High Power LED (front turns and rear brake), 1156 LED Bulb - Single Intensity 3 x 2 Watt High Power LED (rear turns), 74 LED Bulb - 3 SMD LED Wide Angle Wedge Base Cool White (dash).
I just wondered if anyone has used these style bulbs and what you think.
Thank You!
"Common sense is not a flower that grows in everyone's garden"
BobB
« Reply #1 on: March 09, 2015, 11:04:24 AM »
I have swapped nearly all bulbs to LEDs from SuperBright.  Can't remember the exact bulb numbers, but I followed the recommendation of chrise2469 on this board.  He goes into a lot of detail.  Search on "Superbright" to find a lot of help.
72cutlassdude
Laingsburg, MI.
« Reply #2 on: March 11, 2015, 03:32:39 PM »
Thanks Bob,
I ordered the bulbs I listed and couldn't be happier with the results! Now I just have to get the dash bulbs changed out to finish it. Hopefully this Sunday I can tear the fairing apart to get the dash bulbs swapped.
