February 10, 2026, 12:36:10 AM
"clunk" in rear end
Topic: "clunk" in rear end (Read 828 times)
FLAVALK
Winter Springs, Florida
"clunk" in rear end
March 09, 2015, 08:27:08 AM »
When I take off from a full stop, I get a noticeable "clunk" in the rear end when it loads up. It's most noticeable in 1st & 2nd gear. Ya'll think this is a u-joint issue?
Re: "clunk" in rear end
March 09, 2015, 08:29:47 AM »
could be the pinion cup also. you should take it all apart and check the whole drive line.
Louis Durocher
'99 Interstate
Montreal,Canada
March 09, 2015, 08:47:01 AM »
Agree with Gavin
Have a safe ride
March 09, 2015, 09:29:56 AM »
Don't forget the dampeners, if they are loose, Id imagine a cluck could happen
Pete
March 09, 2015, 09:54:30 AM »
When mine started it only clunked on a start with slight left hand lean.
As it progressed it would do it straight up both only in low gear.
Turned out to be splines in the wheel/drive unit.
Replacement fixed it.
The splines were dry. the PO had not serviced them when the wheel was removed.
There were signs of initial paste lube, but it to had dried.
BobB
March 09, 2015, 10:45:57 AM »
My pinion cup failure in 2012 started with single clunks as that spline slipped a single tooth. I only got 250 miles down the road before the clunks turned into a rattle and the Valk stopped moving forward.
FLAVALK
Reply #6 on:
March 09, 2015, 11:37:36 AM »
Thanks all!
