January 28, 2026, 05:09:46 AM *
Author Topic: Rear wheel removal, with belly tank?  (Read 8003 times)
flatsixrider
2000 Standard
Greenville, SC
« on: March 03, 2009, 09:36:38 AM »
I need to pull my rear wheel for the first time since installing the belly tank.  As I have never pulled the rear wheel before, I am looking for some heads-up or warnings.  I would assume the swingarm cannot drop as far now since installing the tank.  Those of you who have done this, can you offer any pointers?  Belly tank removal, exhaust removal, axle removal above exhaust?
Thanks everyone.
Sometimes the appropriate response to reality is to go insane.
Daniel Meyer
The State of confusion.
« Reply #1 on: March 03, 2009, 10:07:15 AM »
I generally pull the shocks and raise the swing arm up to pull the axle out above the exhaust. No problem that way with the belly tank.
CUAgain,
Daniel Meyer
bassin
Arkansas
« Reply #2 on: March 03, 2009, 12:30:49 PM »
If you lift your bike high enough you do not even have to remove the shocks or try  to lower the swing arm it will come out an angle. I loosen the bolts on the exhaust (at the engine and the support bolts)and that allows enough room to remove the axle. Just completed the job last weekend replacing the rear tire. Make sure to check and grease your bearings while you have your tire removed
Dag
Country Rep. Norway
« Reply #3 on: March 03, 2009, 01:37:26 PM »
Loosen the Shocks, lower the bike
Loosen the axle nut and the brake caliper
Pull out the axle
Lift the bike, and its off....
For more detailes: http://www.valkyrienorway.com/RWRemoval.html
flatsixrider
2000 Standard
Greenville, SC
« Reply #4 on: March 03, 2009, 06:13:58 PM »
Thank you all!   Thank you Dag for the pictorial how-to, love how simple these are to put on this board.
Hogg
Longwood {Orlando}, Florida
« Reply #5 on: March 07, 2009, 12:44:54 PM »
 pointing with a screwdriver !  cooldude   I am on my way to hardware store to buy a 27mm socket that will fit the torque wrench.  My Cobra Venom has suffered it's second flat in it's first 1,000 miles.   Cry
Dag
Country Rep. Norway
« Reply #6 on: March 07, 2009, 06:45:36 PM »
I had to check on Wikipedia for G.I. Joe  Smiley
