Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« on: March 15, 2015, 09:17:27 AM » |
OK, so I pulled the headlight bucket and find two wires going to each turn signal so I think "piece o' cake", I'll tap into both wires and the magic of electricity will light my lashes. No such luck, with the key on the runners turn on but not my lashes, when I hit the turn signals the lashes start to blink. Not cool!  How do I wire these guys so the lashes stay on as markers and blink when the turn signals do too? TYIA
Red Diamond
« Reply #2 on: March 15, 2015, 10:08:25 AM » |
3 wires like Poppa said, but I was thinking one of those wires was continuous on for running lights. Think maybe you tapped into the signal side rather than the running light side. LED's shouldn't be much of an added draw.
Houdini
Allen, TX
« Reply #3 on: March 15, 2015, 10:25:50 AM » |
I don't know how I missed the third wire last night ... when I tap into the newly found one instead of the one last night I have marker lashes but they shut off when I turn on the blinkers.
I'm thinking this issue is over my pay grade, is it even possible to have a two wire setup work as a running light and blinker?
RainMaker
Arlington, TX
« Reply #4 on: March 15, 2015, 11:34:46 AM » |
You need Godfire to jump in the conversation.
 2005 BMW R1200 GS 2000 Valkyrie Interstate 1998 Valkyrie Tourer 1981 GL1100I GoldWing 1972 CB500K1
big poppa pump
« Reply #5 on: March 15, 2015, 12:42:51 PM » |
The front running lights are wired to turn off when you switch on the blinkers. The only way you will have running light/blinker with a 2 wire setup is by using diodes.
VRCC#35870 VRCCDS#0266 1998 Valkyrie Hot Rod
Houdini
Allen, TX
« Reply #6 on: March 15, 2015, 01:10:39 PM » |
The only way you will have running light/blinker with a 2 wire setup is by using diodes. Got it, above my pay grade, maybe at one of the up and coming wrench parties I can get this completed.
big poppa pump
« Reply #7 on: March 15, 2015, 01:20:04 PM » |
The only way you will have running light/blinker with a 2 wire setup is by using diodes. Got it, above my pay grade, maybe at one of the up and coming wrench parties I can get this completed. Actually it's pretty straightforward. Get 2 of those metric diode kits from the link I posted. The side with the single wire (blue wire) is hooked up to the positive of the bat lashes. The side with 2 wires (red wires), one connects to the running light and the other connects to the turn signal wire. And that's all to it.
michaelyoung254
« Reply #8 on: March 15, 2015, 02:32:43 PM » |
I'm really not familiar with the so called lashes you are talking about, and how exactly they work, but from what I see with your other post about your new Bat Lashes, it looks to me as though they are supposed to remain "on" as with driving lights. If that's the case, you would be better to tap into the headlight feed circuit instead of the blinker circuit. If my memory serves me correctly, it is blue with a white strip, and it's in the headlight bucket as well. It remains hot as long as the key is on, and turns off when you press the starter button. If you go this route, I wouldn't recommend wiring anything whereas the lights are directly powered by this circuit, but rather to activate a relay which can power the lights.
1998 Standard - Pearl Sedona Red & Ivory Cream
Houdini
Allen, TX
« Reply #9 on: March 16, 2015, 06:45:41 AM » |
The side with the single wire (blue wire) is hooked up to the positive of the bat lashes. The side with 2 wires (red wires), one connects to the running light and the other connects to the turn signal wire. And that's all to it. OK, I ordered two of the diodes. I can do mechanical and fabrication work but electrical has always been like magic to me; maybe it's time to learn how to do this also. Let me ask one more question, thinking about what Michael said, can I tap into the blue/white wire for running light power and tap into the blinker wire to get blinkage? I think getting these guys to blink will be a huge safety improvement.
big poppa pump
« Reply #10 on: March 16, 2015, 07:01:57 AM » |
You can tap into any wire for running light power. Either the blue/white or the orange & blue turn signal wires should work the same.
« Reply #11 on: March 16, 2015, 09:42:41 AM » |
But, I believe if you tap the headlight wire, the lights will never "dim" to give you the blinking you are looking for. I think the diodes tapped into the front turn signals/running lights will give you the look you desire. Hay  Jimmyt
Dred
« Reply #12 on: March 16, 2015, 03:11:21 PM » |
No such luck, with the key on the runners turn on but not my lashes, when I hit the turn signals the lashes start to blink. Not cool!  How do I wire these guys so the lashes stay on as markers and blink when the turn signals do too? TYIA Big Edit: Houdini ... Brew1Brew's insights below change my solutions. I'll need to pay better attention to how Honda engineered the systems before I can offer canned solutions.
« Last Edit: March 16, 2015, 05:05:11 PM by Dred »
brew1brew
« Reply #13 on: March 16, 2015, 03:55:37 PM » |
Chuck, The way honda makes the running lights/blinkers work is as follows
when blinkers are off, through the blinkder switch 12 volts is supplied to both running lights on orange-white (left) and lightblue-white (right), when you turn on a blinder that side breaks the connection to running light lead and applies blinker (intermittent) voltage on ether orange or lightblue depending on what way you push the button. one thing that makes using LED's with the OEM blinkers is that when a blinker is turned on, the turn signal indicator bulb intermittent voltage applied to it, and it gets it's ground through the other side blinker, when when you turn on the right blinker the turn signal indicator gets applies current through the left blinker bulbs, So when you add LEDs packs they can have problems because they detect the current flow coming through the indicator bulb.
but if the lashes have 3 leads, you can try to tap orange-white/lightblue-white for running lights and orange/lightblue for blinkers. if they don't work properly or you only have 2 leads then the diodes from custom dynamics will help.
Les 2014 Valkyrie GL1800 C Blue
5_19
« Reply #14 on: March 17, 2015, 05:03:33 PM » |
http://www.rattlebars.com/valkfaq/circuits.htmlThe turn signal with additional lights is explained really good on Chet's site. If the additional lights that you are installing are low current LED lights and have regular filament turn signal lights you don't need Diodes at all!! Tie your led light to the orange/white and orange on the left and Lblue and LB/white on the right. what will happen is the led will be grounded thru the fillament in the bulb. When the turn signal comes on the Led light goes out and visa versus. I ran that setup for years without any problem.
 Most motorcycle problems are caused by the nut that connects the handlebars to the saddle. IBA # 45723 2001 Honda Valkyrie Standard (Sold after 9 years) 2009 BMW R1200 GSA
godfire
Republic of Texas
« Reply #15 on: March 20, 2015, 07:13:16 PM » |
Hey bro... do you have things working? Grounding through the filament... good stuff.... they do that just to make us crazy...
« Last Edit: March 20, 2015, 07:17:19 PM by godfire »
Ride Safe Ride Often
Houdini
Allen, TX
« Reply #16 on: March 21, 2015, 12:43:55 PM » |
Hey bro... do you have things working? Not yet Jim, I put the headlight back in so my fellow commuters could admire my new accent lights last week, maybe I'll pull it back apart this weekend since my diodes arrived a few days ago.
RainMaker
Arlington, TX
« Reply #17 on: March 21, 2015, 01:44:16 PM » |
Draw him a diagram. Then we'll all know how to do it!
