February 10, 2026, 02:20:17 AM
Air cleaner lower oring ???
Topic: Air cleaner lower oring ??? (Read 801 times)
flcjr
Manhattan,Montana
March 19, 2015, 08:02:56 PM »
New o rings no shape to them. Any tricks to getting the lower one in place???
Joevalk
Santa Fe, Texas
Re: Air cleaner lower oring ???
March 19, 2015, 08:07:55 PM »
Whatchu talkin bout Willis?
VRCC#32720
1999 Grn/Silver Interstate
flcjr
Manhattan,Montana
March 19, 2015, 08:15:24 PM »
Parts break down shows seal above and below air cleaner in air box lower one doesn't want to stay in place long enough to get filter in place
March 20, 2015, 05:19:39 AM »
There should only be one between the upper and lower half of air box. I lay it in the groove on the bottom half then put top on. Don't see any other way,it does come out sometimes but hasn't been a problem to get in.
indybobm
Franklin, Indiana VRCC # 5258
March 20, 2015, 05:42:58 AM »
Never noticed before but the parts fische does show two and lists the quantity at two seals.
So many roads, so little time
VRCC # 5258
Attic Rat
VRCC # 1962
Tulsa, OK
March 20, 2015, 06:00:15 AM »
there is a top and a bottom o ring for the air box
Reply #6 on:
March 20, 2015, 07:10:39 AM »
Quote from: Attic Rat on March 20, 2015, 06:00:15 AM
I guess my top one has stayed put on both because I have never seen but one
flcjr
Manhattan,Montana
Reply #7 on:
March 20, 2015, 10:57:50 AM »
I got new ones. Top one fits good bottom one won't stay in place. I'll just use some stickem to hold in place
Dorkman
San Carlos, CA
Reply #8 on:
March 21, 2015, 05:54:29 PM »
A little grease will hold it down. If someone had a K&N air filter on the bike, the seal may be missing. Don't think the K&N's needed the seal, at least the K&N I removed.
Reply #9 on:
March 21, 2015, 06:07:36 PM »
Quote from: flcjr on March 20, 2015, 10:57:50 AM
Use some grip cement to tack difficult areas.
My rides:
