February 10, 2026, 02:20:55 AM *
Author Topic: front end clunks on bumps  (Read 1216 times)
Tfrank59
'98 Tourer
Western Washington
« on: March 19, 2015, 08:05:53 PM »
So when I hit a large bump or series of them, I hear and feel a clunk in my front end somewhere.  don't believe it's in the wheel assy--checked and rechecked it.  I know the fork tubes are tight in the triple clamps.  Would it be the steering head bearings?  If that's the likely thing, how to check those--jack the bike up and start pulling?  Thanks.
-Tom
longrider
Vernon, B.C. Canada
« Reply #1 on: March 19, 2015, 08:47:16 PM »
I've got it too.  calipers have a bit of play on the pins.  nothing to worry about
N8171S
Marlboro, Mass
« Reply #2 on: March 20, 2015, 03:36:33 AM »
Check all the pinch bolts on the forks
3W-lonerider
Shippensburg Pa
« Reply #3 on: March 20, 2015, 04:01:01 AM »
take the spring clip out of the front brake calipers and put some more curve into it and re-install. your pads are bouncing in your calipers because those spring clips aren't keeping enough tension on them.. don't go ballistic on bending them though. doesn't take a whole lot. you'll be able to feel if you have enough tension or not when you go to put them back in.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: March 20, 2015, 05:38:54 AM »
Next time when you go over bumps lightly apply the front brakes and see if the noise goes away.
So many roads, so little time
VRCC # 5258
baird4444
« Reply #5 on: March 20, 2015, 03:08:17 PM »
http://www.rattlebars.com/valkfaq/index.html#NOISE
IT GOES CLUNK WHEN I STOP! It sure does! The Valkyrie is equipped with "floating" calipers. The calipers are attached to the caliper brackets (these, not the calipers, are bolted to the forks) by a set of rubber booted pins set in holes. The holes are larger than the pins so there is some free play there. When you back your bike up to turn it around and apply the brake in reverse, the calipers will move to the rearmost position. When you apply the brake at the next forward stop the calipers move to the forward most position and the pins strike the other sides of the holes.. CLUNK! You can see the calipers move if you apply the brake and rock the bike forward and back. When you stop at a red light, the calipers will move to the forward most position then when the bike "rocks back" after being stopped... CLUNK!
    - ya gotta be SOBER!
     -Cody Baird
Tfrank59
'98 Tourer
Western Washington
« Reply #6 on: March 20, 2015, 05:04:48 PM »
Yes, I'm aware of the clunking when I apply the brakes – this is clunking over bumps.  Still, based on everybody's input here it might just be the calipers bouncing around or something. I wonder if they have a bit too much "float" in them. Grin  Thanks for the feedback.
-Tom
RonW
Newport Beach
« Reply #7 on: March 20, 2015, 07:04:27 PM »
Just did the (rear) brakes a few days ago, and the curve in the clip does tend to flatten out a bit, specifically develop a larger radius. I had a new spring clip to compare side by side.
2000 Valkyrie Tourer
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: March 20, 2015, 09:13:51 PM »
Okay, I guess I better get into my front brakes and put more tension in that spring clip.  Thanks again.
-Tom
indybobm
« Reply #9 on: March 21, 2015, 06:14:37 AM »
Mine clunked when going over bumps, until I lightly applied the front brake. Front pad springs need some work and make sure the pin that the pads slide on are clean and lightly greased.
VRCC # 5258
Tfrank59
'98 Tourer
Western Washington
« Reply #10 on: March 21, 2015, 07:03:23 AM »
Okay, will do.  I'm just relieved that it's not my steering head bearings or something much more serious.
-Tom
