January 29, 2026, 01:58:08 PM *
Author Topic: no power to fuse block  (Read 1733 times)
bamalancedriver
« on: August 25, 2009, 07:51:22 AM »
I went to start my bike and the headlight, taillight, tach, and the lights on the headlight ie neutral bright light indicater is not working. cleaned the starter switch, bike cranked just fine. i checked the fuses and all of them were ok. checked the power to the switch block going from top to bottom of the fuses. power to the first, fourth, and fifth fuse. two, three, and six had no power. Thanks
Madmike
Campbell River BC, Canada
« Reply #1 on: August 25, 2009, 09:10:21 PM »
http://www.rattlebars.com/valkfaq/schematics/rpage02.html
here's a link to the schematic..  there are 3 circuits fed from a common wire from the ignition switch but you will have to identify the circuits by name as the info that you have given would rule that out if teh placement of teh fuses is correct in the schematic that I have....
Dag's site has teh manual available if you go there...
