February 10, 2026, 02:21:03 AM *
Author Topic: What is a good easy to use engine/grime cleaner?  (Read 1632 times)
lljjmm
« on: March 21, 2015, 04:42:52 PM »
Need a good easy to use engine cleaner, any recommendations?  Thanks for any input
« Reply #1 on: March 21, 2015, 04:54:13 PM »
Simple green.
dpcarson
Lillington, NC
« Reply #2 on: March 21, 2015, 05:22:03 PM »
Easy off oven cleaner
« Reply #3 on: March 21, 2015, 06:07:06 PM »
S100 or mag wheel sprays, are mildly corrosive (wear nitrile gloves), sprayed and stiff bristle brushed/scrubbed on the bottom and low sides, engine, and wheels/brakes, and rinsed very well before dry does a nice job (on a cold bike).  I always follow up with hot soapy scrub, because corrosives can etch aluminum permanently if you don't get it all off.  You can also just use any auto parts engine degreaser, but it leaves a bigger mess.
Never do the whole bike, so nothing dries.  Do it in sections, and keep it wet.  When done, wash the whole bike.
« Reply #4 on: March 21, 2015, 06:09:22 PM »
Simple green.
Works great!  cooldude  Be sure to blow dry when finished with the rinse.
My rides:
« Reply #5 on: March 21, 2015, 06:11:16 PM »
Simple green.
Not Simple Green....MEAN GREEN from the dollar store.  Simple green is harsh on aluminum
Its the only thing I use
« Last Edit: March 21, 2015, 06:15:54 PM by Chrisj CMA » Logged
Gideon
Indianapolis, IN.
« Reply #6 on: March 21, 2015, 07:10:34 PM »
  Wink S100 or Mag Wheel Spray. Both work great.  cooldude
da prez
Wilmot Wi
« Reply #7 on: March 21, 2015, 08:39:31 PM »
 Ditto on the Mean Green. Also ,Dawn liquid dish soap diluted 50/50. Spray on heavy and let it soak or even dry .  Spray again and rinse off . Works wonders.
                                       da prez
« Reply #8 on: March 21, 2015, 09:31:46 PM »
Because I've had a bad experience with the alkali degreasers and aluminum mags, I would use soap (dish washing liquid) and water with a brush of your choice (paint, soft or med bristles).
PharmBoy
Lawton, Ok
« Reply #9 on: March 22, 2015, 05:45:55 AM »
Krud Kutter Parts Washer is one that I recently discovered and I'm totally sold on it.  There are several kinds of "Krud Kutter", but the "Parts Washer" is non-flammable, non-irritating to skin, and leaves metal parts clean and shining after applying with a brush.  It cleans brake calipers better than brake cleaners.  It is the one with a gray label and is available at Home Depot, Tractor supply, and some Wall-Mart stores. It is about $14/gal and a gallon goes a long way...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
dpcarson
Lillington, NC
« Reply #10 on: March 22, 2015, 05:47:51 AM »
This thread has inspired me.  I think I am going to go outside and wash the bikes,  If I can get the leaf blower to crank that is.
PharmBoy
Lawton, Ok
« Reply #11 on: March 22, 2015, 06:05:08 AM »
It's raining here, so maybe I should just roll mine outside...Jim 2funny
99 Interstate
97 Bumble Bee
97 Red & White
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #12 on: March 22, 2015, 06:53:30 AM »
Krud Kutter parts cleaner gray label you can buy it at tractor supply for about 13.00 per gal. It will not hurt aluminum or paint. I like to use the regular red label that you can buy at home depot to clean the shop floor. I just spray it on brush it a little and then let it set for about 10 minutes then spay in on again and brush it. Then just wipe it off or rinse with water either way cleans great
« Reply #13 on: March 22, 2015, 07:14:30 AM »
Simple green.
Been using simple green for about 20 yrs with ZERO adverse effect.
Bone
« Reply #14 on: March 22, 2015, 08:17:59 AM »
On the back of the Mean Green 40 FL.OZ. bottle: Not Recommended for use on glass, aluminum, chrome alloy wheels, varnished or painted surfaces.
Bought this a year or two ago haven't used it fearing the label.
« Reply #15 on: March 22, 2015, 08:40:24 AM »
Just by looking at Chris's bike I'd say that is just a disclaimer for future possible litigation.
Not to many bikes look as good as his.
Bone
« Reply #16 on: March 22, 2015, 08:48:07 AM »
Oh I agree if mine looked like Chris's I'd be afraid to ride in my climate.
Guess I should just look at their warning as a legal precaution of the seller.
« Reply #17 on: March 22, 2015, 08:55:23 AM »
Read the label on simple green it says it is non toxic, bio degradable and safe for most anything you can imagine. All it says is don't clean Hot parts with it.
Bone
« Reply #18 on: March 22, 2015, 09:13:15 AM »
The spray bottle I have of Simple Green doesn't have that warning but does have the Good House Keeping seal.
Says it's safe to use for general cleaning.
« Reply #19 on: March 22, 2015, 09:19:18 AM »
The bottle I have is Automotive.
« Reply #20 on: March 22, 2015, 09:46:12 AM »
My only addition to this is..... If you want something to do a bunch of the work for you (I do), mild corrosives do that (esp if the bike is really greasy and grimy to start with).  If you are worried about mild corrosives (and your bike is really pretty clean anyway), then just use soap and work harder than you need to.
Nothing cleans up my brake calipers like mild corrosives, except when I have them apart I use gun cleaning bore solvent (Shooter's Choice is best, or Hoppe's) and pistol rods and stainless and brass brushes.  Does not adversely affect the pads either.
Regular brake cleaner is a waste of time, and really only good for blowing crud which is already loose off the parts being cleaned (and into your eyes).
Farther
Quimper Peninsula, WA
« Reply #21 on: March 22, 2015, 01:06:43 PM »
My bike seems to get and stay dirty because when it is nice enough to wash the bike it is nice enough to ride.  Guess which wins!!  When I do wash the bike it is with car washing soap and cold water from the garden hose.  Finish up with Lemon Pledge on everything from leather to exhaust to windshield to engine.
~Farther
« Reply #22 on: March 22, 2015, 02:36:08 PM »
I looked it up on HD web site, but no grey label. 4 @ $15 and one @ $21 saying Spray Gun and Parts Cleaner
I did look up WalMart. Found it for $17+
« Last Edit: March 22, 2015, 08:17:30 PM by gordonv » Logged
dpcarson
Lillington, NC
« Reply #23 on: March 22, 2015, 05:36:14 PM »
Other thing I have used that works really nice, Mr. Clean lemon scent cleaner.  Works great and leaves a nice shine.  By the way, this stuff is also awesome on jewelry and removing the skin  oils and is very mild on jewelry.
Pappy!
Central Florida - Eustis
« Reply #24 on: March 22, 2015, 05:41:03 PM »
For something like the greasy underside of an engine I use the standard Gunk Engine degreaser. Works extremely well. That Krud Kutter is something I think I will look into though.
For almost all normal dirt and grime I use the mildest detergent I think will work. Several various brushes to go with it. Leaf Blower to dry it off and Pledge or whatever you choose to finish it off with.
« Reply #25 on: March 22, 2015, 07:55:58 PM »
DP, I don't know about down your way, but up here in Spring time, it can be some real excitement using anything lemony.  Had the yellow jackets after me the last two years.  I wiped them out each time (after the little peckerwoods sandbagged me), at least on my property, but they are never gone.  Using lemon pledge in my back yard is like some kind of homing signal.  One or two show up fairly docile, and shortly thereafter the extended family shows up like jihadis.
« Reply #26 on: March 22, 2015, 08:59:20 PM »
 2funny 2funny 2funny 2funny 2funny 2funny
dpcarson
Lillington, NC
« Reply #27 on: March 23, 2015, 03:07:46 AM »
Your just laughing because all th e bees are scared of your bike!  Like the Incredible Hulk of bees!!
« Reply #28 on: March 23, 2015, 07:57:03 AM »
simple green will turn aluminum dark if soaked in it for hrs. it is really a problem for higher grade aluminums.
their degreaser formula is even more caustic to aluminum than their everyday formula.
now this is how it was 7+ yrs ago, don't know if they changed it.
« Reply #29 on: March 23, 2015, 09:30:22 AM »
Why would one soak anything for hours? And as I stated 20 yrs with ZERO problems.
« Reply #30 on: March 23, 2015, 11:31:02 AM »
WOW! wasn't contradicting your no "ZERO" problems in 20 yrs.
 was only stating facts about simple green. search why the army and air force have prohibited its use on certain materials esp. high grade strength aluminums.
why do u think people would soak a really dirty, greasy part if it says degreaser?
U mean to tell me u never soaked any kind of parts ever?
CoachDoc
San Diego, CA
« Reply #31 on: March 23, 2015, 04:25:13 PM »
Lots of guys use Simple Green as a carb cleaner. Works great, especially with an ultrasonic cleaner, but
I have seen the aluminum body carbs from vintage Honda SOHC Fours turn dark if immersed too long in the Simple Green solution. When just used as a cleaner I've never had a problem with my bikes and I use it all the time.
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
« Reply #32 on: March 23, 2015, 07:31:08 PM »
What's the wow about? I was just inquiring. And yes I can honestly tell you that I have never shake and parts other than internal engine parts.
