November 20, 2025, 05:11:19 AM *
Author Topic: Petcock Mod & Question  (Read 3130 times)
Ken 11861
Lunenburg, MA
« on: August 25, 2009, 08:45:42 AM »
I made a modification to the Honda vacuum petcock yesterday and although it works now like I hoped it would, I need to know if you all know of any problems I may have caused by this mod.
I decided to make this mod because I already replaced the petcock vacuum parts last July 2008 with the replacement kit. Then yesterday while I was cruising steady at about 85 she started to feel like it was running out of gas so I flipped to reserve (had at least half a tank of gas still), it didn't seem to smooth out til I slowed to about 60 for a while. When I go home I sucked on the vacuum line for the petcock vacuum diaphram & sure enough it was leaking by.
Anyway basically & simply (KISS) I cut a piece of gasket material & sandwiched it between the main valve body and the other aluminum plates, I abandoned the diaphrams, springs, etc. Now it operates just mechanically. I tried it in OFF, ON & Reserve positions & it seems to be working fine.
I have considered the Pingle Petcock in the past but was not happy with the access for switching to Reserve while riding, I can find the Honda knob with my eyes closed: (professional riders on a closed loop course only).
Anyway please let me know of any pitfalls to my modification, maybe my fix has been written up in archives before but I missed it.
2001 Valk (72,500 5/2011) & 2009 ST1300 (new 5/10)
Joe Hummer
Arnold, MO
« Reply #1 on: August 25, 2009, 08:50:02 AM »
The only problem I can see is that you MUST remember to turn your gas off at every stop.  If one of your carb floats is sticking any, you could flood a cylinder with gas.  When you try to start the bike, you will hydrolock the motor causing damage to the starter gears (at a minimum).
Joe
1999 Valkyrie Interstate
Mr.BubblesVRCCDS0008
« Reply #2 on: August 25, 2009, 11:01:54 AM »
I did this last Nov. to make a ride and never have had any problems. I just started making a habit of turn key on turn fuel on , turn key off turn fuel off. I'm planning on getting an electric shut off but haven't yet.
Rocketman
Seabrook, Texas
« Reply #3 on: August 25, 2009, 11:53:31 AM »
You're a rare breed:  A Houston member who has heard my preaching and actually turns the fuel off!  You're a group of one!
I feel vindicated!  Justified!  Elated!
Oh, wait.  It had nothing to do with my preaching, just a quick fix.
Oh well.  I'll keep preaching the "shut it off, vacuum or not" gospel anyway.
Everyone:  SHUT YOUR FUEL OFF EVERY TIME.  It could save you some serious time/money/heartache.  I don't care if you have a vacuum shutoff.  It could fail, and frequently does, apparently.
Grandpot
Fort Mill, South Carolina
« Reply #4 on: August 25, 2009, 12:00:17 PM »
I did a similar mod to my petcock and added a solenoid valve.  Hooked up the solenoid valve to the 5 AMP auxiliary wires under the right side cover.
Don't forget to turn off the petcock, just in case! cooldude
Ken 11861
Lunenburg, MA
« Reply #5 on: August 25, 2009, 05:07:29 PM »
Thanks Guys,
I feel safer with your comments & do shut mine off all the time too Cheesy.
scoobydoo
Evansville, Indiana
« Reply #6 on: September 10, 2009, 07:28:26 PM »
Can you explain a little more how to make this mod. What to take out & what the gasket looks like and is made of?
thanks Scooby
