Valkpilot
What does the data say?
Corinth, Texas
« on: March 23, 2015, 08:28:34 AM » |
How many folks would be available for a wrench party this Saturday?
If so, chime in with what you want to get done.
Baron
« Reply #1 on: March 23, 2015, 09:40:03 AM » |
I will be. I may need some help if I don't get my turn signals working and installing a CB.
Ride safe,
Baron VRCC 28275 2000 Valkyrie Interstate 2023 Road Glide Limited 2022 KLR 650
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #3 on: March 23, 2015, 12:50:07 PM » |
+1
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #4 on: March 23, 2015, 02:21:50 PM » |
Wish I could, I still need my aux driving lights and headlight relay wired up but Brianna has a Softball doublheader on Saturday.
Maybe next time.
RainMaker
Arlington, TX
« Reply #5 on: March 23, 2015, 02:49:28 PM » |
Busy on the Continental Avenue Bridge with the Easter Bunny.
 2005 BMW R1200 GS 2000 Valkyrie Interstate 1998 Valkyrie Tourer 1981 GL1100I GoldWing 1972 CB500K1
Timbo
« Reply #6 on: March 23, 2015, 03:00:13 PM » |
I would be happy to be there. I have ordered front and rear bearings, and hope they arrive before then ( but I believe there are some spares that I can replenish if my order doesn't get here in time). I also need to put new oil in my forks.
BuzzKill
« Reply #7 on: March 23, 2015, 04:18:51 PM » |
I can probably make it till about 1pm. Not sure what I need at the moment. Sounds like alot of work to do. I call dibs on being primary heckler.
Wheelman
« Reply #8 on: March 24, 2015, 07:53:44 AM » |
I'd like to go to the dark side and I have to replace the valve stem in the front. Is this something for the wrench party or shall I take it to a dealer/mechanic? If so, any suggestions on a dealer or mechanic?
Thank you for your time,
Bob 214-869-4668
LEFT LANE FOR PASSING ONLY OR SLOWER TRAFFIC KEEP TO THE RIGHT, WHICHEVER WORKS BETTER FOR YOU.
Valkpilot
Corinth, Texas
« Reply #9 on: March 24, 2015, 10:25:45 AM » |
So, I count - 3 rear drive services -- 2 with tire changes
- 1 front tire change
- 1 front tire breakdown for valve stem replacement
Fair warning: It's going to be a long day. I've got one working lift and one lift adaptor. We're going to need at least one more of each and two would be preferred so that three bikes can be in process at the same time.
Disco
Republic of Texas
« Reply #10 on: March 24, 2015, 10:37:24 AM » |
Wow, sounds like lots of big work to be done. None of it's really hard, but there will be lots of steps. So, to help ensure that everything gets done, for those of us with projects, we need to be prepared to do our own disassembly and reassembly work. There will be plenty of armstrong labor to help with the physical stuff, plenty of Valkyrie-specific knowledge, and lots brain power to help with the special stuff. I'll bring a lift, the football, and the special tools. Rumor has it there will even be several mystery guests...
« Last Edit: March 24, 2015, 01:00:36 PM by Disco »
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
Baron
« Reply #11 on: March 24, 2015, 03:27:16 PM » |
I have a motorcycle lift if someone can come by and pick it up.
Ride safe,
BnB Tom
Frisco, TX
« Reply #12 on: March 25, 2015, 04:59:17 AM » |
Fair warning: It's going to be a long day. I've got one working lift and one lift adaptor. We're going to need at least one more of each and two would be preferred so that three bikes can be in process at the same time. I hope we have time for my little (  ) list of goodies. Rear tire, rear drive, front and rear brakes, oil change, coolant flush/change, clutch lever bushing, new battery, 12v power center to handlebars, CB mount and LUNCH!
Disco
Republic of Texas
« Reply #13 on: March 25, 2015, 09:24:54 AM » |
You ought to be thinking front tire, too, Tom.
Valkpilot
Corinth, Texas
« Reply #14 on: March 25, 2015, 10:29:44 AM » |
Bob 214-869-4668
We can help you. (I included your work in the list above.) Be prepared to get greasy.
« Last Edit: March 25, 2015, 10:42:08 AM by Valkpilot »
Valkpilot
Corinth, Texas
« Reply #15 on: March 25, 2015, 11:00:48 AM » |
Let's start at 0900. I'll have coffee available and if we're real sweet to Buzzkill, I'll bet he'll pick up donuts and kalaches for us.If you've never been or can't remember where I live, PM me through the board for address information. Please let me know who you are, because I won't respond to names/handles I don't recognize.For those of you planning tire changes, I strongly encourage you to bring some Ride-On with you, unless you are using DynaBeads to balance your tires. I like Ride-On because it both balances and provides puncture protection in the center tread area of the tire. I estimate that my front tire wear was extended 50% after starting to use it. I can't say that it was all due to the Ride-On, but it sure didn't make things worse. Cycle Center of Denton stocks it at the same price you can buy it online: about $14/bottle. You'll need one bottle for the front and between 1-1/4 and 1-1/2 bottle for the rear, depending on tire. Also, check your brake pads as this is a good time to change them if needed. We have standard O rings for the rear drive at no charge. I do not have spares of rear wheel dampers or brake pads -- these were depleted at other wrench parties and I haven't re-stocked. I believe I have spare bearing sets which can be had for the price of replacements. One bay of the garage will be taken up by the tire changer. The other bay by one bike on a lift. We can work on several more bikes in the driveway, provided we have lifts and adaptors. My hope is to have at least two of the rear drive services/tire changes in progress concurrently. My advice for anyone planning an extended trip or if your drive line has not been serviced recently is that we check it from the output shaft back, i.e., pull the u-joint for inspection. Since we're not NASCAR pit crews, expect at least a hour and a half to do a rear drive service and tire change. Flap-jawing and grab-assing (or is it grab-jawing and flap-assing?) extends this rather dramatically. Baron, if you bring your bike, I'll try and help you with your turn signal issue. Apparently Tom has volunteered to arrange for lunch.
« Last Edit: March 25, 2015, 06:08:22 PM by Valkpilot »
Christbiker
« Reply #16 on: March 25, 2015, 05:05:38 PM » |
You just might see my ugly mug there but I'm not being sweet to Buzzkill
Blessings
HE>i
Valkpilot
Corinth, Texas
« Reply #17 on: March 25, 2015, 06:05:48 PM » |
Blessings
Hope you make it, Woody. And just remember, being sweet to Buzzkill can yield unexpected rewards!
Baron
« Reply #18 on: March 25, 2015, 07:54:55 PM » |
Thanks VP!  You know Randy is a great guy  and a model Prez
Ride safe,
BnB Tom
Frisco, TX
« Reply #19 on: March 26, 2015, 03:37:53 AM » |
Apparently Tom has volunteered to arrange for lunch.  1 - 800 - PIZZA MAN
Timbo
« Reply #20 on: March 26, 2015, 05:22:30 AM » |
Thank you VP for arranging this gathering...
Disco
Republic of Texas
« Reply #21 on: March 26, 2015, 09:09:58 AM » |
If anyone forgets their Ride-On, I'll have plenty-o-DynaBeads.
If anyone discovers they need to replace their u-joint and doesn't have a spare in their saddlebag, or if you just want to have one in your saddlebag, I'll have you covered. Well, not everyone. Supply limited to the first four two.
« Last Edit: March 26, 2015, 12:41:27 PM by Disco »
brew1brew
« Reply #22 on: March 26, 2015, 11:11:15 AM » |
Has anyone volunteered to be the acting director/executive management? Someone to do a little bit of Pidgin management, swoop in and crap on everything! Well, I'll volunteer to bring a dozen donuts from Dunkin Donuts and to lend a hand at something that won't get my hands dirty  Generally I will lend moral support and provide a bit of humor.
Les 2014 Valkyrie GL1800 C Blue
BnB Tom
Frisco, TX
« Reply #23 on: March 26, 2015, 12:02:17 PM » |
... lend a hand at something that won't get my hands dirty I understand there are surgical gloves available.
BnB Tom
Frisco, TX
« Reply #24 on: March 27, 2015, 04:19:10 AM » |
I'm sure Disco is not suggesting that you mix and match this concoction! It's one OR the other
godfire
Republic of Texas
« Reply #25 on: March 27, 2015, 07:35:01 PM » |
Now Tom.... since I'm not there to have your back... be sure to be on your best behavior.... or not!
Ride Safe Ride Often
lucky_1_chris
« Reply #26 on: March 28, 2015, 01:59:40 AM » |
Count me in. Gotta knock a few things out with work in the morning, so it may be close to noon before I get there. I can bring a lift adapter.
1999 Valkyrie Interstate
BnB Tom
Frisco, TX
« Reply #27 on: March 28, 2015, 04:59:14 AM » |
Now Tom.... since I'm not there to have your back... be sure to be on your best behavior.... or not!  Hey there big man. Good to hear from you . Hope everything is going well with you and yours. Wish you were here so I could throw a little aggravation your way. ( I keep plenty in stock as you well know  )
« Last Edit: March 28, 2015, 05:02:35 AM by BnB Tom »
BnB Tom
Frisco, TX
« Reply #28 on: March 29, 2015, 09:57:28 AM » |
WOW!! What a crowd!!  I guess everybody decided to take advantage of the beautiful weekend and jump on their bikes. Think, at one point, there was between 12 -15 people there. Maybe 10 bikes. A BIG thanks to Valkpilot for hosting this event.  He certainly pulled out all the stops when it came to providing the space, equipment, tools and expertise!!  Started with the first bike in the open bay (mine) at around 8:45 am and Valkpilot said the last person left after 8:30 pm... do you think he was tired?  Everybody got some or all of his help on their misc. projects: Tire changes, rear drive servicing, brakes, electrical and on and on. Most everyone there either had something they needed help on or they were helping someone who needed an extra hand or suggestion. Kudos to all... especially to Dave
« Last Edit: March 29, 2015, 10:00:37 AM by BnB Tom »
Six Guns
« Reply #29 on: March 29, 2015, 08:29:25 PM » |
Baron
« Reply #30 on: March 30, 2015, 06:47:08 AM » |
Yes, big thanks to Dave for hosting the party and being up to his neck in all the grease  It was great having coffee and dunkin donuts for the morning and the chicken and all the appitizers for lunch. What a great group to be a part of  I got my turn signals working thank to TJ  Next time I will have to remember to take some pictures.
Ride safe,
Valkpilot
Corinth, Texas
« Reply #31 on: March 30, 2015, 02:27:17 PM » |
Aw, shucks. :  Seriously, it was quite a day. We did - 4 tire changes (1 front, three rear)
- 1 front valve stem (so another tire breakdown)
- 2 u-joint inspections (which means two boot re-installations)
- 1 turn signal fix (Thank you 5-19)
- 1 stem-to-stern breakdown (front & rear bearings, drive splines, pinion splines, u-joint) chasing an odd vibration in Timbo's bike.
Funny, it doesn't look like much now... P.S. Thank you to whoever put money in the cigar jar for shop supplies. It will be put to good use for future get togethers.
RainMaker
Arlington, TX
« Reply #32 on: March 30, 2015, 03:57:59 PM » |
I would have loved to have been there. But I was instead on the Continental Bridge in a photo shoot with an 18 year old bunny.
Valkpilot
Corinth, Texas
« Reply #33 on: March 30, 2015, 06:08:02 PM » |
I would have loved to have been there. But I was instead on the Continental Bridge in a photo shoot with an 18 year old bunny.  ...who appears to be eating the head of a small child. Seems like a sketchy business plan, devouring the clientel that way. Limits the repeat revenue a little, no?
RainMaker
Arlington, TX
« Reply #35 on: April 01, 2015, 01:51:28 PM » |
Great Pics, Jackie! Looks like you could have yelled "DAVE" and half the place would have snapped to attention.
Baron
« Reply #36 on: April 02, 2015, 06:27:23 AM » |
Jackie, Thanks for taking the pics
Ride safe,
