February 10, 2026, 02:20:56 AM *
Author Topic: I/S Steering Seems Tight, Heavy After Storage  (Read 1198 times)
rugguy
2000 Valk I/S
Atlanta, GA
« on: March 24, 2015, 06:35:27 AM »
Picked up my '00 I/S from heated, tendered storage yesterday and trailered it home. When I rode it around the neighborhood last it just didn't feel right. It's like the steering is tight and the front end is "heavy"....I haven't ridden it in a while...Michigan winters are tough. I had the bike in Colorado through a winter and didn't experience this.
I know the bike wasn't ridden or dropped during storage because the mileage was the same out as in and I checked for "storage rash" and found none. Plus, the shop it was stored at is AAAA+++. Tire pressure is close enough to spec to not cause this type of slow speed feel.
Anyone experience anything like this before?
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
Bone
« Reply #1 on: March 24, 2015, 06:51:28 AM »
I'm in Michigan and cold tires with normal pressure feel really low. Maybe air them up a easy thing to try.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #2 on: March 24, 2015, 06:58:07 AM »
Thanks Bone.....I will try that.....
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #3 on: March 24, 2015, 07:21:04 AM »
What you describe has all the symptoms of low tire pressure.  Maybe check with a different gauge?  What were your actual pressure readings?  What do you consider to be "spec"?
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #4 on: March 24, 2015, 10:27:33 AM »
Guess I'm re-checking TP tonight....
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #5 on: March 24, 2015, 03:07:01 PM »
Obviously you left the heavier more dense winter air in your tires.
You need to change out for the lighter spring/summer air.   Wink
« Reply #6 on: March 24, 2015, 04:40:49 PM »
You don't say what tires you have. Avon Cobras on my valk. Run 42F and 46R. Most folks are at the 40 PSI range.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #7 on: March 25, 2015, 08:14:57 AM »
I run Avons..front was 40 rear was 44......never known two lbs to make that big a difference......but I will correct and report.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #8 on: March 25, 2015, 08:40:17 AM »
Keep us informed. Nitpickingly exact pressures might enhance tire life, but I
could happily wear out a set of Avons at those pressures...
« Reply #9 on: March 25, 2015, 10:54:54 AM »
Also as suggested above use a different tire gauge to make sure the one you are using is correct.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #10 on: March 25, 2015, 12:12:51 PM »
You are a year older now. Maybe it's just too heavy for ya now  Evil
Keep us posted  cooldude
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #11 on: March 26, 2015, 10:42:27 AM »
Well, there's a lesson learned. Apparently everything came through the winter in good shape EXCEPT for my $20 air gauge. I checked the TP with a gauge off my other bike and I was running 30/32. Should be 40/46 for my Avons with one rider. Pumped them up to correct specs and handles like a dream. Go figure.....
Thanks for the advice....
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #12 on: March 26, 2015, 03:12:34 PM »
I at one time had three different gauges (one on each bike but different gauges) I found out they all read different uglystupid2 so I bought one good digital gauge and just use it and have had no problems since.
RonW
Newport Beach
« Reply #13 on: March 26, 2015, 05:02:34 PM »
I keep my tire gauge wrapped in bubble wrap in addition to the pouch it came with (in saddlebag). For vibration some, but more to cushion it against the occasional bounce.
2000 Valkyrie Tourer
