February 10, 2026, 02:35:26 AM
RAM mount..... which bolt
Topic: RAM mount..... which bolt (Read 798 times)
wct69
March 28, 2015, 12:49:02 PM »
I have a RAM mount base ( RAM-B-367U ) Handle bar clamp base with M8 screws.
It comes with three different length bolts to use.
I am going to place it in the lower right hand corner of four bolt pattern.
Does anyone happen to know which bolt I will be using. Depth is the issue.
Chris
Farther
Quimper Peninsula, WA
Re: RAM mount..... which bolt
March 28, 2015, 01:06:21 PM »
I have the same mount. Slip the bolts through the ball and compare the exposed threads to the exposed threads from the stock clamp bolt that you remove and you will find your answer.
~Farther
March 28, 2015, 02:55:12 PM »
I believe you remove the bolt, and measure the thickness of the mount, and choose the bolt that is that thickness longer than the stock one. This is how I did my Shadow.
