February 10, 2026, 04:16:27 AM *
Author Topic: First Spring Ridus Interruptus  (Read 2254 times)
SpidyJ
Murrells Inlet
« on: March 30, 2015, 03:48:18 AM »
So I get everything back together with new tires, rear service, brakes etc and first thing that happens asfter I turn the petcock on is I smell gas........then I see gas.
It's dripping from up above the carbs somewhere......offf comes the tank.
Hope it's something simple.
 crazy2 tickedoff
« Last Edit: March 30, 2015, 09:27:30 AM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #1 on: March 30, 2015, 03:50:10 AM »
Have you had it off recently? Didn't list any service you did that should affect that. Curious
Brewer
Denver, CO
« Reply #2 on: March 30, 2015, 04:16:10 AM »
Look for the leak in the fuel lines then the fuel rails. A small inspection mirror and fuel safe light will help.
Brewer - it is a hobby
BobB
« Reply #3 on: March 30, 2015, 05:15:55 AM »
Had the same thing happen to me this spring.  Someone here mentioned that fuel seals dry out.  The issue corrected itself.
SpidyJ
Murrells Inlet
« Reply #4 on: March 30, 2015, 05:48:47 AM »
I did replace the intake "O" rings too but didn't take the tank off or touch anything else.
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #5 on: March 30, 2015, 05:49:40 AM »
Where are the fuel seals?  Part of the carburetors?
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #6 on: March 30, 2015, 05:52:44 AM »
It's a pretty good leak so this is the first place I'll look, main line, branches then rails.
It's dripping from all three carbs on the left side so I suspect the rail or branch line feeding that side.
Peace,
johnnywebb
BobB
« Reply #7 on: March 30, 2015, 06:27:59 AM »
There are seals on the fuel rails that transfer fuel to all three carbs on each side.  My carbs were leaking on both sides.
SpidyJ
Murrells Inlet
« Reply #8 on: March 30, 2015, 12:06:33 PM »
I can't find these seals on the OEM parts list.  Don't see a part called a fuel rail either?!
Peace,
johnnywebb
« Reply #9 on: March 30, 2015, 03:20:18 PM »
Fuel rail O-rings have dried out some. Now that you bathed them in gas, they will probably swell enough that leaks will stop.
Check to see if there are leaks in 24 hrs.
My rides:
SpidyJ
Murrells Inlet
« Reply #10 on: March 30, 2015, 04:54:09 PM »
Man I hope you're right....it looks like the carbs have to be removed and seperated to replace them.
 Sad
Peace,
johnnywebb
Flint
NY
« Reply #11 on: March 30, 2015, 04:56:31 PM »
Spidyj ,
Part #4 16039-MZ0-670  are the O rings under, carb assembly
Part #1  16024-MZ1-790 is the joint set, fuel, under carb assembly
Part  #2 16024-MZ0-000 joint set, fuel, under carb tubing
If it ends up that its the seals you will need 16 of them, 8 fuel, 8 vent there all the same part #
Good luck. Flint
2006 VTX 1800C3
1999 blk/orange standard
1997 blk standard
Brewer
Denver, CO
« Reply #12 on: March 30, 2015, 05:32:41 PM »
fuel rail kit with 'better' o rings: http://redeye.ecrater.com/p/6738361/carb-fuel-rail-leak-kit
SpidyJ
Murrells Inlet
« Reply #13 on: March 31, 2015, 03:51:27 AM »
Thanks guys.  We'll see if it's still leaking tonight.
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #14 on: March 31, 2015, 05:28:29 PM »
Thanks fellas..........it stopped leaking.....not a drop.
Glad I posted or I would have torn into it immediately.
Y'all saved me alot of grief!!!
 cooldude Grin Cool Kiss coolsmiley
Peace,
johnnywebb
« Reply #15 on: March 31, 2015, 08:00:05 PM »
Glad to here SpidyJ. You know someday those fuel rail O-rings need to changed. At least that's what I keep telling myself.  2funny
My rides:
SpidyJ
Murrells Inlet
« Reply #16 on: April 05, 2015, 06:50:22 AM »
The fuel rail is leaking again.  Not when hot and riding.......only when cold in the garage overnight.
It may be time for replacement and maybe desmog at the same time......unless you guys know of something like a gas treatment that will swell the shut?!?
 Roll Eyes Cry tickedoff crazy2
Peace,
johnnywebb
« Reply #17 on: April 05, 2015, 06:58:10 AM »
Did you turn the Petcock off after it stopped leaking? Then turn it on and it leaks again? If so turn it back on and leave it on.
SpidyJ
Murrells Inlet
« Reply #18 on: April 05, 2015, 07:24:55 AM »
Yes, I turned the petcock off.
Turn it back on....what will that do?  I have a Danmarc too.
Peace,
johnnywebb
Pappy!
Central Florida - Eustis
« Reply #19 on: April 05, 2015, 08:35:47 AM »
swell up the O rings that are leaking.
« Reply #20 on: April 05, 2015, 10:47:43 AM »
SpidyJ  stuff paper toweling under the carbs and in the carb valley.  Open the petcock and start the bike and watch if you can see where gas is coming from. If the flow is hard, shut the bike down, if not, let it run a min or so. Check it again,  after 24 hrs and after removing the toweling,  by  starting it. If it's still leaking, you have a carb repair in your future.  tickedoff
My rides:
« Reply #21 on: April 05, 2015, 12:15:41 PM »
Well if you turn it off and run the bowls dry the seal also dry,so when turned back on they will leak again. Also I would like to ask why would you turn the petcock off if you have a Dan Marc? Hell I have never turned mine off since 1997 (and no I don't have a Dan Marc or pingle) except when I removed the tank it stays in the on postition unless I need to switch to reserve.
SpidyJ
Murrells Inlet
« Reply #22 on: April 06, 2015, 12:47:51 PM »
Yeah.....I guess I'm paranoid about HydroLok.  Just some extra inn shurance.
Once you've had it, you will avoid it at all costs.
It didn't leak last night.........Yahoo.......(I think).
Yer bike sure is yeller.............I like it!
Peace,
johnnywebb
« Reply #23 on: April 07, 2015, 04:35:45 AM »
Thanks.
I always just bump the starter button when starting if it turns then hit the starter.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #24 on: April 07, 2015, 07:07:00 AM »
Replace the carb "o"'s. Why wait for them to leak all the time...which they will eventually do. If you are handy with a wrench and are willing to take your time you can do it in a day. Redeye's kits are Vitron and have everything you need to do the job right. There is a great video series online too that you can watch first. https://www.youtube.com/watch?v=eDLTpQCTBsc Believe me the hardest things will be the choke return springs reattachment (if you don't pay attention) and re-installing the @#!%&# airbox (you will want a friend's help to do that). And those require patience more than technical know-how. Change out the intake runner "o"s while you are at it...another simple job and should be done at the same time. Don't ask me how I know....
« Last Edit: April 07, 2015, 07:08:32 AM by rugguy » Logged
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
« Reply #25 on: April 07, 2015, 08:04:40 AM »
It's not so simple as that!!!
Read about the problems related to just getting the carburetors apart.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #26 on: April 07, 2015, 08:16:01 AM »
Never said it was easy brother...I said he could do it (Changing the "o"s in the intake runners is simple). I've done my carbs twice and don't possess any special talent or skill. Basic tools, a Clymer manual, videos and this forum got me through it both times (and a little beer too). But it's a darn-sight better that waiting until you are away from home on a ride and can't stop the leak(s) then. Those "o" rings are going bad and eventually their age and the pressure in the line will cause them to leak with the engine running. Flammable liquids+hot engine+7 gallons of fuel+between my legs = not going to happen. Plus, the stress kills the fun. Once you "think" they're leaking you'll start to smell gas all day whether they are leaking or not.....just my two cents worth....
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
SpidyJ
Murrells Inlet
« Reply #27 on: April 07, 2015, 10:26:32 AM »
I've had the air box off twice and replaced the intake runners  this winter. I am not afraid to tackle this............I juss wanna ride .......NOW!
I am a "research the job endlessly then tackle it"  kinda guy so I know I can do it.
So much work for a few "O" rings.
Do I hafta sync the carbs after reassembly?
Peace,
johnnywebb
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #28 on: April 07, 2015, 10:40:50 AM »
I'm sure you should but I never have done a full sync. I did a down-and-dirty manual sync after carb overhaul and my '00 runs like a scalded dog and my "butt-dyno" says it's all good.
P.S....next time...no need to take out the airbox just to replace intake runner "o"s......loosen all six clamps first, then there wlil be enough "wiggle" room from the airbox to get runners out and back in without scratching the machined faces. Learned that here too.....
« Last Edit: April 07, 2015, 10:47:18 AM by rugguy » Logged
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
