February 10, 2026, 02:35:24 AM *
Author Topic: Flickering Temp Light  (Read 721 times)
tvgod
« on: March 30, 2015, 07:27:07 AM »
I've read a lot of the posts about the temp light flickering. My '98 Tourer has starting doing this but it seems to correspond with another electrical functions. It seems to flicker with the fan coming on and if the turn signal is on the light flickers in rhythm with the turn signal. Is this consistent with what others have experienced? The rest of the story is that this started on the first ride after getting the bike out of the shop after having the carbs rebuilt.
Randy
« Last Edit: March 30, 2015, 07:30:41 AM by tvgod » Logged
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: March 30, 2015, 07:42:26 AM »
If it was a bad sensor, I would think that the 'phantom' hot light would happen with no rhyme or reason.  On my '97, there was nothing that happened at the same time.  It would just come on at weird times.  Using a temperature gun, I did a side by side with another Valk, and mine was the same temp, after warm up, as the other...  Blinking with the turn sounds like a short or bad ground.  Check that a wire was not pinched or skinned with the carb work.
Black Dog
Don't you know...
