February 10, 2026, 02:35:09 AM *
Author Topic: Clutch grabbing just before clutch lever hits grip...........  (Read 1189 times)
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« on: March 30, 2015, 12:45:07 PM »
Is the cable worn and needing replaced or is this another issue. All I know is on a 150 mile ride today I noticed it grabbing right at the grip and prayed I'd make it home to look over. Disengages and engages fine but concerned on it running out of room to disengage. Hope the gurus here can make a determination on this little bit of info. Thanks in advance.
twdurdentwd
Sebastian, Florida
« Reply #1 on: March 30, 2015, 12:59:55 PM »
How's your fluid level? May be slave cylinder..
00' Valk tourer - 6-6, trigger wheel
00' Valk std - complete build
00' I/S salvaged.. Transplant to std
Williamsburg, KY
« Reply #2 on: March 30, 2015, 01:11:14 PM »
Pulled cap and yes it is low on fluid and may have been that way for awhile.   Sad Haven't noticed anything leaking but maybe you don't see it. Should I just get some fluid and bleed it clean and filled and keep an eye on it or is there a way to know the slave is bad?
Daniel Meyer
The State of confusion.
« Reply #3 on: March 30, 2015, 01:26:57 PM »
I'd start with a clean/bleed/fresh fluid and keep an eye on it.
CUAgain,
Daniel Meyer
Williamsburg, KY
« Reply #4 on: March 30, 2015, 01:42:14 PM »
Thanks Daniel. At least if the slave does need attention it ain't in the Tranny like my Ranger.  tickedoff
« Reply #5 on: March 30, 2015, 01:52:01 PM »
Think again.
Williamsburg, KY
« Reply #6 on: March 30, 2015, 02:01:16 PM »
Think again.
That's what I love about you Ricky. Your sarcasm is always so helpful   crazy2
Brewer
Denver, CO
« Reply #7 on: March 30, 2015, 02:26:54 PM »
It is worthwhile and easy to examine the lever, brass bushing, pivot point and plunger for correct fit and function. The brass bushing can wear out. Good luck with the repairs.
Brewer - it is a hobby
twdurdentwd
Sebastian, Florida
« Reply #8 on: March 31, 2015, 01:11:02 AM »
Think again.
Not sure what you're talking about.... No it's not in the tranny.
Williamsburg, KY
« Reply #9 on: March 31, 2015, 04:04:05 AM »
Think again.
I know the manual shows lower back of engine. cooldude
« Last Edit: March 31, 2015, 04:05:57 AM by KY,Dave (AKA Misunderstood) » Logged
twdurdentwd
Sebastian, Florida
« Reply #10 on: March 31, 2015, 08:42:01 AM »
Think again.
Punisher
No, not vengenance. Punishment.
« Reply #11 on: March 31, 2015, 10:11:16 AM »
If fluid, bushings and such all check out my bet would be the rivets in the clutch damper plate.   What year, model and mileage we talking about?
Williamsburg, KY
« Reply #12 on: March 31, 2015, 12:12:44 PM »
97 with 42,000
Valkpilot
What does the data say?
Corinth, Texas
« Reply #13 on: March 31, 2015, 01:24:41 PM »
+1 and +1 what Daniel said.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Williamsburg, KY
« Reply #14 on: March 31, 2015, 02:05:14 PM »
Thanks, That's the direction I'm taking it.
Probie (Scooter57)
Auburn Georgia
« Reply #15 on: March 31, 2015, 02:32:41 PM »
Mine is doing the same thing, I'm gonna swap out the fluid but I'm looking for what type fluid to get...I have a quart of Blinker fluid out in the garage will that work?  crazy2
Williamsburg, KY
« Reply #16 on: March 31, 2015, 03:13:44 PM »
Hard to find dot 4 anymore. I got a Dot 3/4 that states to be used in all dot 4 vehicles. Got it at auto store. Zone/Advance/Oreilly etc
« Reply #17 on: March 31, 2015, 04:40:12 PM »
Valvoline DOT4 at most auto stores. I get mine at Autozone.
