February 10, 2026, 04:16:16 AM
Fuel Vaccuum line replacement
Topic: Fuel Vaccuum line replacement (Read 1006 times)
Mosa
April 02, 2015, 04:01:56 PM »
OK, did a quick search with nothing quick to see... anyway, replacing aging vaccuum line from petcock to #6 and need to know the proper size of the line...whats the ID?
Thanks, Mosa
Re: Fuel Vaccuum line replacement
April 02, 2015, 04:39:08 PM »
Can't remember exact size, maybe 3/16's ID. Take a piece to the auto parts store and match it up as close as possible. Look for windshield washer hose.
Attic Rat
VRCC # 1962
Tulsa, OK
April 02, 2015, 05:22:53 PM »
Thanks Sandy for pointing that out to me. I stand corrected 3.5 MM is the correct size I wouldn't want to give the wrong info
http://www.boostcontroller.com/TurboLogic-Vacuum-Hose-3-5MM-p/tls-vh-3.5.htm
Last Edit: April 02, 2015, 08:08:51 PM by Attic Rat
April 02, 2015, 06:01:57 PM »
Mr. Rat: I've always believed the ID is 3.5 mm. If you want it locally, the sized is 5/32nds.
zzed28
Midland Michigan
April 02, 2015, 06:07:23 PM »
I just bought one today, my bill says 7/32nds. I took a snip off mine and took it with me, so it should be right.
da prez
Wilmot Wi
April 02, 2015, 09:49:59 PM »
If I measured right , the nipple diameter is .170. .1875 is 3/16. .01625 is 1/64th of an inch. I used a 3/16 line an that is all that they had at the time. So at 11:50 at night going from memory , it is 11/64.
B U T ,what hair are we splitting.
da prez (believe atticrat , he knows)
Reply #6 on:
April 03, 2015, 04:52:56 AM »
BobB
Reply #7 on:
April 03, 2015, 06:27:31 AM »
My grey hair is .003" in diameter. So what are we now talking about?
Farther
Quimper Peninsula, WA
Reply #8 on:
April 03, 2015, 08:47:10 PM »
Just get it from Redeye.
http://redeye.ecrater.com/p/2064169/oem-petcock-vacuum-line-viton-b
~Farther
